Herman Eggink
- Jan 27, 2014
I just built my first Freenas box replacing my old DNS323. So far pretty happy with it: nice performance, easy config, lots of functionality.
BUT, as always, hind sight is an exact science and had I known then...
My key challenge is that, having a 4 2TB drive system, Freenas ended up configuring ZFS mirroring the 2 drives. In essence not bad but I have stuff (e.g. OSX backups) that don't really require a mirror.
Is there an 'easy' way to reconfigure the storage such that I can 1) unmirror one of the mirrored disks, 2) move some of the volumes (specifically the time machine volumes) to another volume without having to reconfigure the entire box, 3) add the previously mirrored disk as a non mirrored volume and then 4) move the time machines back?
I am happy to attach a separate esata disk to support the move. Luckily, I don't that much data just yet so the moves should be fairly fast. I just noticed that all the mount points (and thus all the sharing) is based on the volume name so changing this immediately affects what's being shared, right?
Thanks for helping!
H
Thanks for helping!
H
