alexhore
- Sep 24, 2014
I know the admins and experienced users don't like permission questions we are simply expected to learn for ourselves but I have read the section in the Freenas 9.3 guide regarding storage and as far as I can tell set it up in a way that should work.
So I wanted to setup Transmission and a few other Plugins to use the same storage but without leaving the folders open to all.
I can read and write to the folders using Freenas user Alex who is also part of the group I created called System but the transmission user I setup using the same username and group name and even the ID number 921 from the jail seems unable to despite having System as an Aux group.
I'm 4 hours, 3 installs and 5+ removal and re-installs of transmission and storage closer to finding someone I can pay for an answer, please consider removing this thorn from my left cheek.
Transmission error:
Storage I'm trying to share:
Transmission user:
Groups:
Shared folder permissions:
I made an assumption that this step in the guide (shown below) means create this additional group in Freenas not in the jail/jails perhaps this is the reason?
If the jail should access existing data, edit the permissions of the volume or dataset so that the user and group account has the desired read and write access. If multiple applications or jails are to have access to the same data, you will need to create a separate group and add each needed user account to that group.
Transmission error:
Transmission user:
Groups:
