Startup Problems
dustbull
When starting the server I have the problem that the boot-pool is not imported automatically and must be imported manually (screenshot). If I import the pool with the command "zpool import -o readonly=on boot-pool", the further startup process works until the point where the middleware service is started, there it stops. The whole thing occurs now all at once, the last 3 months there were never problems. The stick is recognized in the BIOS. Sure, the start always took a while, but now it just aborts. It doesn't matter how often I restart the service via systemctl, it stays in the same state even after 10 hours. I hope you can do something more with the information.
The version is 22.02.1
Installed on a USB drive (unfortunately still)
As HW I use the HP Proliant Microserver Gen8
Attached some screens
Cheers
neofusion
The images list errors due to the drive being read only; something that typically happens when the drive has essentially died.
Hopefully you saved a copy of your config-file, otherwise I expect you will have to redo the configuration from scratch.
I can't see anything in the images that suggest that your normal data pools are affacted though, so you should be able to import them when you get a new install up and running.
