boscorillium
- Jan 13, 2017
I don't know if all of this is related but I just did the upgrade to 22.02.0.1 from 22.02.RELEASE. I have a pool job that won't finish and is stuck at 80% even though it's fully imported into the system and available.
Then SMB wouldn't start. So I had to dive into that and this is what I found and had to do:
Missing directories:
That made it so I could start SMB services and for now that's fine but not ideal. Is this known? Surely it's not expected....
Also- can we have an option to mark pools optional at boot? Having boot take in excess of 15 minutes because it can't import an encrypted pool (password protected) is annoying.
Hope this is helpful to someone!
sudo mkdir /var/db/system/samba4/private sudo systemctl restart smbd cd /var/log sudo mkdir samba4 sudo systemctl restart smbd
