manfromafar
- Mar 2, 2015
Hello all;
I assume (and am highly confident) that most people here know far more about hardware then I.
What I really need help with is selecting the hardware for the current build. Over the past 2 years I've accumulated over 40TB of "stuff". Now that I have money and the space I am looking to move the storage from single HDDs to one massive box that has room to grow.
The major things I need are:
1 cpu
Motherboard that supports ecc ram
I am looking at 16GB of Crucial ecc unbuffered ram
A power supply to run at the least 12 6TB WD Reds ( This will need to be able to expand to other pools later on as I expect my data to continue to grow at a steady pace)
As those are the major hurtles right now thats what I'll focus on.
I plan to be doing mostly light transcoding of video files and most machines I have in the house will be able to play back the video files perfectly fine without the use of transcoding... That being sad apple products still arnt the best with this so I will need to take that into account.
To house everything I'm planning on just building my own case as that will be the easiest to do.
To connect all the HDDs together I am looking at the Highpoint 750 HBA card as it allows up to 40 Disks to be combined into one PCIe slot. This will help with future expansion.
I hope to have the build down to around 600-700$ Canadian if possible. This excludes the cost of the HBA card and the drives of course.
Doing some of the research I have cobbled together a starter build:
I've been looking at the SeaSonic SSR-360Gp Plus Gold Certified Power supply
Crucial 16GB (2X8GB) ecc unbuffered Ram
A Pentium g3240
SuperMicro X10SLM-F-O (SUPERMICRO MBD-X10SLM-F-O uATX Server Motherboard LGA 1150 Intel C224 DDR3 1600 ) Mother board
Thanks for the help or if there is non thanks anyways.
1 cpu
A Pentium g3240
