Hello I retired my old Freenas system and began a new build Poweredge T410
Truenas core is up and running
Plex is up and running
Sabnzbd up and running
My issue, as with my last build, is having Sabnzdb, Sonarr using the same datasets, files whatever...
In general: setup.
I have a pool "Media Programs" 1tb Mirrored drives. This is where my jails are contained for Plex, Sabnzbd
I have a second Pool "Tank" this is a 4tb drive. Mirrored later. This is where the data "movies, music, etc" is saved
Sabnzbd mount point Source can exist inside or outside its pool. Media Programs, or tank.
its destination mount point will only allow to exist in its own pool "Midia Programs".
I believe the destination pool/dataset should be where my Movies and tvs are saved in pool tank.
My thoughts are, Sabnzbd mount points should be
Sources /mnt/Media Programs/iocage/jails/sabnzbd/root/usr/local/sabnzbd/Downloads because this is where sabnzbd downloads to.
Destination /mnt/tank/Media/Movies This destination is not selectable or present.
I read that Programs and Media data should be saved in different pools for several reasons. But I believe this is causing my issue.
It was time consuming on the last build to always move downloads and arrange them. I'm sure if done correctly sab, sonarr will do this for me.
I don't mind rebuilding and reconstructing if I must. Any help is appreciated but Please help with more than just code statements, I'm not to familiar with Truenas and what I know I forgot 10 years ago. Yes I have done many searches, and read many outdated freenas 11.3 posts.
In general: setup.
