Thefarelkid
- Oct 29, 2016
I'm trying to follow this tutorial to back up to a Synology NAS from FreeNAS but I cannot get it to accept my SSH key. I can't figure it out and I've done this successfully many times before. Logging in with password works fine, and as the output below shows, the sshconfig is set to allow for keys. What am I missing here?
I'm running FreeNAS 9.10.2-U5 and Synology DSM 6.1.3-15152.
rsync-backup@freenas:~ % ssh -v -i .ssh/id_rsa rsync@192.168.1.150 OpenSSH_7.4p1, OpenSSL 1.0.1u-freebsd 22 Sep 2016 debug1: Reading configuration data /usr/local/etc/ssh/ssh_config debug1: Connecting to 192.168.1.150 [192.168.1.150] port 22. debug1: Connection established. debug1: identity file .ssh/id_rsa type 1 debug1: key_load_public: No such file or directory debug1: identity file .ssh/id_rsa-cert type -1 debug1: Enabling compatibility mode for protocol 2.0 debug1: Local version string SSH-2.0-OpenSSH_7.4-hpn14v5 debug1: Remote protocol version 2.0, remote software version OpenSSH_6.8p1-hpn14v6 debug1: match: OpenSSH_6.8p1-hpn14v6 pat OpenSSH* compat 0x04000000 debug1: Authenticating to 192.168.1.150:22 as 'rsync' debug1: SSH2_MSG_KEXINIT sent debug1: SSH2_MSG_KEXINIT received debug1: kex: algorithm: curve25519-sha256@libssh.org debug1: kex: host key algorithm: ecdsa-sha2-nistp256 debug1: REQUESTED ENC.NAME is 'chacha20-poly1305@openssh.com' debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none debug1: REQUESTED ENC.NAME is 'chacha20-poly1305@openssh.com' debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none debug1: expecting SSH2_MSG_KEX_ECDH_REPLY debug1: Server host key: ecdsa-sha2-nistp256 SHA256:5kFRSNTCjoW+LQtxnTvM5DAutgEE2Ix9qK8KV3F2qy0 debug1: skipped DNS lookup for numerical hostname debug1: Host '192.168.1.150' is known and matches the ECDSA host key. debug1: Found key in /mnt/Pool2/home/rsync-backup/.ssh/known_hosts:1 debug1: rekey after 134217728 blocks debug1: SSH2_MSG_NEWKEYS sent debug1: expecting SSH2_MSG_NEWKEYS debug1: SSH2_MSG_NEWKEYS received debug1: rekey after 134217728 blocks debug1: SSH2_MSG_SERVICE_ACCEPT received debug1: Authentications that can continue: publickey,password debug1: Next authentication method: publickey debug1: Offering RSA public key: .ssh/id_rsa debug1: Authentications that can continue: publickey,password debug1: Next authentication method: password rsync@192.168.1.150's password:
