Boot USB stick replaces - fixing post-migration issues.
Perm1990
Member
Hello.
Due to my boot USB stick shows some problems I've installed the FreeNAS anew on new USB stick + restored the settings.
Now I have several problems:
- How I can copy my old FreeNAS Stick to restore my previous scripts and other data. If I mount the pool from the USB Stick, the mount directry is empty.
- If I try to login via ssh I got this error:
Dass-iMac-2obsolete:~ denis$ ssh root@freenasprimary.fritz.box -v
OpenSSH_7.8p1, LibreSSL 2.6.2
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 48: Applying options for *
debug1: Connecting to freenasprimary.fritz.box port 22.
debug1: Connection established.
debug1: identity file /Users/denis/.ssh/id_rsa type 0
debug1: identity file /Users/denis/.ssh/id_rsa-cert type -1
debug1: identity file /Users/denis/.ssh/id_dsa type -1
debug1: identity file /Users/denis/.ssh/id_dsa-cert type -1
debug1: identity file /Users/denis/.ssh/id_ecdsa type -1
debug1: identity file /Users/denis/.ssh/id_ecdsa-cert type -1
debug1: identity file /Users/denis/.ssh/id_ed25519 type -1
debug1: identity file /Users/denis/.ssh/id_ed25519-cert type -1
debug1: identity file /Users/denis/.ssh/id_xmss type -1
debug1: identity file /Users/denis/.ssh/id_xmss-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.8
debug1: Remote protocol version 2.0, remote software version OpenSSH_8.0-hpn14v15
debug1: match: OpenSSH_8.0-hpn14v15 pat OpenSSH* compat 0x04000000
debug1: Authenticating to freenasprimary.fritz.box:22 as 'root'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:QkDEQ/3uwPswa+u2tChzfQYG8exxW1QpRrc4PEILJAo
debug1: Host 'freenasprimary.fritz.box' is known and matches the ECDSA host key.
debug1: Found key in /Users/denis/.ssh/known_hosts:7
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey
debug1: Next authentication method: publickey
debug1: Offering public key: RSA SHA256:cG/mfVtxfjEu1sEKPD/igvzaxjF/pHyG1fBW8skwmwI /Users/denis/.ssh/id_rsa
debug1: Trying private key: /Users/denis/.ssh/id_dsa
debug1: Trying private key: /Users/denis/.ssh/id_ecdsa
debug1: Trying private key: /Users/denis/.ssh/id_ed25519
debug1: Trying private key: /Users/denis/.ssh/id_xmss
debug1: No more authentication methods to try.
root@freenasprimary.fritz.box: Permission denied (publickey).
FreeNAS 11.3
Perm1990
Member
Update: If I mount the old boot USB Stick it is "empty".
Here is 'zpool list' results
NAME USED AVAIL REFER MOUNTPOINT
freeNASOld 14,4G 13,9G 321K /Users/denis/_Temp/ZFS/
freeNASOld/ROOT 14,3G 13,9G 25K /Users/denis/_Temp/ZFS//ROOT
freeNASOld/ROOT/11.1-U5 17,4M 13,9G 858M /
freeNASOld/ROOT/11.1-U6 17,2M 13,9G 858M /
freeNASOld/ROOT/11.1-U6.3 20,5M 13,9G 804M /
freeNASOld/ROOT/11.1-U7 19,0M 13,9G 763M /
freeNASOld/ROOT/11.2-U8 23,1M 13,9G 786M /
freeNASOld/ROOT/11.3-U1 194K 13,9G 1,01G /
freeNASOld/ROOT/11.3-U2 230K 13,9G 1,01G /
freeNASOld/ROOT/11.3-U5 14,1G 13,9G 1,02G /
freeNASOld/ROOT/9.10-STABLE-201604140622 8,29M 13,9G 502M /
freeNASOld/ROOT/9.10-STABLE-201604181743 8,90M 13,9G 466M /
freeNASOld/ROOT/9.10-STABLE-201604261518 8,71M 13,9G 472M /
freeNASOld/ROOT/9.10-STABLE-201605021851 9,05M 13,9G 490M /
freeNASOld/ROOT/9.10-STABLE-201605240427 71K 13,9G 492M /
freeNASOld/ROOT/9.10-STABLE-201606072003 8,25M 13,9G 602M /
freeNASOld/ROOT/9.10-STABLE-201606270534 9,53M 13,9G 604M /
freeNASOld/ROOT/9.10.1 10,1M 13,9G 624M /
freeNASOld/ROOT/9.10.1-U1 10,2M 13,9G 632M /
freeNASOld/ROOT/9.10.1-U2 11,2M 13,9G 633M /
freeNASOld/ROOT/9.10.1-U4 98K 13,9G 651M /
freeNASOld/ROOT/9.10.2-U1 14,4M 13,9G 650M /
freeNASOld/ROOT/9.10.2-U3 13,8M 13,9G 652M /
freeNASOld/ROOT/9.10.2-U4 13,8M 13,9G 652M /
freeNASOld/ROOT/9.10.2-U5 13,2M 13,9G 652M /
freeNASOld/ROOT/9.10.2-U6 15,4M 13,9G 654M /
freeNASOld/ROOT/Backup 1K 13,9G 518M legacy
freeNASOld/ROOT/Initial-Install 1K 13,9G 513M legacy
freeNASOld/ROOT/Pre-FreeNAS-9.3-STABLE-201602031011-984250 70K 13,9G 514M /
freeNASOld/ROOT/default 6,34M 13,9G 520M legacy
freeNASOld/ROOT/last_stable 1K 13,9G 520M legacy
freeNASOld/grub 70,7M 13,9G 6,95M legacy
