thijsjek
- Aug 12, 2017
I am trying to set up ssh keys for security and learn how to do it on FreeNAS-11.0-U4
What did i do so far:
Made on my windows machine with puttygen a public and private key (with auth) and called it id_rsa.ppk.
FreeNAS GUI, i have a user with sudo permissions, a home directory and i pasted the public key without ---- BEGIN SSH2 PUBLIC KEY ---- etc.
Sanity checked ~.shh/authorized_keys so that its 1 row [edit]
disabled password login and started ssh service.
Putty: selected the .ppk and connected to server.
Problem:
when i connect with putty i get the fatalerror:
Disconnected: No supported authentication methods available (server sent: publickey)
Logs:
Permissions:
Problem:
Logs:
tail -f /var/log/messages
Freenas sshd[17271]: error: Received disconnect from xx.xx.xx.27 port 53203:14: No supported authentication methods available [preauth]
tail -f /var/log/auth.log
Oct 9 12:16:30 Freenas sshd[10801]: Server listening on :: port 22. Oct 9 12:16:30 Freenas sshd[10801]: Server listening on 0.0.0.0 port 22. Oct 9 12:16:32 Freenas sshd[17271]: error: Received disconnect from xx.xx.xx.27 port 53203:14: No supported authentication methods available [preauth] Oct 9 12:16:32 Freenas sshd[17271]: Disconnected from xx.xx.xx.27 port 53203 [preauth]
Permissions:
homedirectory itself: drwx------ 3 user user 3 Oct 9 09:59 User Inside home directory: drwx------ 2 user user 3 Oct 9 09:59 .ssh File: -rw------- 1 user user 373 Oct 9 11:23 authorized_keys
