Space Upgrade Advice
Wally
I currently have my freenas setup with 2x3TB Red in mirror. I am now at 95%. I have purchase another 3TB Red and I also have spare a 2TB Black and 1TB Purple. I am very broke now and cant afford any more purchases for 9 months. I need advice on what I can do for more space. All HDD are installed in the machine already. There is also a 60GB SSD installed but not used. All HDD and the SSD range from brand new to 1 week old.
I had a thought, the 2tb and 1tb in raid0 to make a 3tb. Then the striped 3tb and the new 3tb red mirrored. Then the two mirrors striped for 6tb usable. Another note: I currently have 0 backups and in order to store 3tb worth, it will take multiple computers and laptops to handle the space but possible (2-3 days worth of transferring).
DrKK
FreeNAS Generalissimo
Lord in Heaven, please preserve Wally.
FreeNAS (and ZFS) is a very poor solution for someone with random collections of variable-sized drives. Your proposed solution is horrifying to me, if I can even understand it, and in fact, I am not convinced you can do what you propose at all really (certainly not from the GUI).
What I would do in your spot is:
1) Pray
2) Immediately buy a 4TB external USB drive for around $140, and immediately back your pool up.
3) Take the 2TB black and 1TB purple and throw them in the garbage can
4) Take your (now) 3x3TB reds, and make a RAID-Z pool of the three drives, for a total of ~6TB usable.
5) Restore onto your pool from the 4TB external USB drive
6) Pray, especially because steps 4-5, if something goes wrong, your data is gone.
Maybe someone else will have a different idea, but I don't think you're getting out of this without spending another $150-$200 Canadian.
DrKK
Also, sir, if your pool is at 95%, then that is **MUCH TOO HIGH**, that is an *EMERGENCY* in ZFS. Your data is potentially at serious risk RIGHT NOW.
DrKK
OK, I am told by some people in the IRC that it's not clear if data is at actual risk for overfull pools, BUT, I can assure you, we consider a 95% ZFS pool to be a very bad situation.
Wally
Hey DrKK,
Thanks for the advice; thats a good idea. I went through my data and cleaned up the junk or unneeded files. I am now down too 2.1TB (77%). I have a brand new external 2 TB drive, which I forgot I had. It is not enough but I can make it work for now. Now I am thinking I should shell out for another 3TB and do 4 drives and hopefully be set for a while. I am living off my visa at the moment while in school but I need this to be complete so I don't have to do all this again soon. Guess I will shell out another 180$ Canadian rupies.
Kind Regards,
Matthew W.
tvsjr
I'd hate to think how much power you're chewing through (plus the HVAC to cool the heat) runninng that Opteron beast to handle a pair of drives. You'd probably save enough money on the light bill to justify building up one of the common Dell/Lenovo/etc. microservers. Not to mention the reduction in size, noise, etc.
Wally
Hey everyone,
Got an update. Went with 4x3TB WD Red in raidz2. Took some figuring out but everything is happy now and I am transferring my files back from my backup. 2TB Black will be used as a 2nd backup with the external. 1TB Purple is going in the surveillance system for extra memory. Things are running great now but slower speeds. Before 100-110mb/s now 50mb/s up to 80mb/s for large files. I don't know if it is normal or not. Network is not the bottleneck.
tvsjr,
Probably a decent amount of power, I benefit from the heat though. In summer I will be venting in and out, outside. Size = large due to large case (Corsair 700D). Noise is high only because of fans on 12v only (I will be correcting this). Otherwise it is fine. I will use it for a year or so then upgrade. I am getting a new server tomorrow too.
Kind Regards,
Wally
