Kevin Horton
- Dec 2, 2015
The modular SeaSonic PSU for the NAS box I'm building didn't come with enough 15 pin SATA power cables, and it seems that SeaSonic doesn't sell extra modular cables. I could order some custom cables from Ensourced, or I could use some sort of 4 wire Molex plug to 15 pin SATA adapter. It seems that I should be careful to purchase something with good quality 15 pin plugs, to avoid potential shorts and fires.
DigiKey Canada sells Molex brand adapters, and looking at the specs for those, it seems that they are assembled from Molex 15 pin plugs and crimped pins. I've assembled quite a few Molex connectors in the past, and based on that experience I suspect that the Molex 15 pin SATA plugs are sufficiently high quality to minimize the risk of shorts and fires. But, I'd appreciate any comments from those who may be familiar with these parts before I order them.
Note: although the folks on this forum tend to use "Molex" to refer specifically to the four pin connectors used on older SATA drives, Molex in fact makes a huge variety of connectors, including 15 pin plugs used on current SATA drives. I'm using Molex to refer to the brand in this post, not just one type of plug.
Is anyone familiar with the quality of the 15 pin SATA plugs from Ensourced?
