Sonarr/NZBdrone problems
wtfR6a
Its been running perfectly for ages now but appears to be having some issues starting. Some googling suggests this may be an incompatibility with FreeBSD 10.3 rather than a nzbdrone or config issue and I wondered if anyone else was or is experiencing any problems. This is the error I get when starting the app
$ /etc/rc.d/run_drone
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
D
dlavigne
Guest
Was this installed as a plugin or by hand within a jail? What is your current build version (from System -> Information)?
wtfR6a
Manual install from `http://update.sonarr.tv/v2/master/mono/NzbDrone.master.tar.gz`
# mono -V
Mono JIT compiler version 4.2.1 (Stable 4.2.1.102/6dd2d0d Fri Dec 25 03:07:52 UTC 2015)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
    TLS:           __thread
    SIGSEGV:       altstack
    Notification:  kqueue
    Architecture:  amd64
    Disabled:      none
    Misc:          softdebug
    LLVM:          supported, not enabled.
    GC:            sgen
Just to verify I even spun up a new install and did a clean install in latest stable, FreeNAS-9.10-STABLE-201605240427 (64fcd8e)
SweetAndLow
Sweet'NASty
Does it work if you install from pkg?
Did you follow these instructions: https://github.com/Sonarr/Sonarr/wiki/Installation-FreeBSD
Also freebsd and mono have issues when it comes to translating some syscalls into freebsd friendly calls. I use 9.3 right now but will test on 9.10 to help you out.
wtfR6a
I pretty much followed the second set of instructions from Sweet&Low's link, i.e
mv /usr/local/etc/pkg.conf /usr/local/etc/pkg.conf.backup
pkg install mono mediainfo sqlite3
cd
fetch http://download.sonarr.tv/v2/master/mono/NzbDrone.master.tar.gz
tar -xzvf NzbDrone.master.tar.gz
ee /etc/rc.d/run_drone
I also set my advanced options to include the sysctl's
set advanced options of jail = allow.raw_sockets=true,allow.sysvipc=1
as suggested by the mono installer when being run in a jail. I hadn't set it previously and it ran fine and I can confirm it did not fix the issues either. I can verify it is being set through sysctl -a | grep sysvipc.
I tried installing from packages too which didn't work either.
wtfR6a
SweetAndLow
Sweet'NASty
Yes I did test it and something was messed up with the packages that day. Have you tried again since making your post.
wtfR6a
No - but Im running out of TV to watch so might have to try and work on it remotely! thanks for following up.
wtfR6a
updated to latest FreeNAS stable: FreeNAS-9.10-STABLE-201606072003 (696eba7), updated my usual jail but no joy, still the SIGSEGV error.
However, I created a new jail, did a simple pkg install installation and it started right up. I'll do some more debugging to see what else might have changed, at least I got further than last time.
wtfR6a
ok. Im not sure whats going on here, something to do with freeNAS jails or FreeBSD which is beyond my current knowledge.
My new test jail, and my previous jail both demonstrate the same functionality now so at least Ive tracked down the root cause.
If I start Sonarr/NzbDrone from the 'root' account via system shell access in the FreeNAS GUI, it starts without issue.
If I try and start the program from root user (via 'su') or a user which has been added to the wheel group, it fails with immediate SIGSERV error.
diedrichg
No - but I'm running out of TV to watch
Let me help you out:
Black Sails
The Flash
The Walking Dead
Continuum
Gotham
Stargate SG-1
Farscape
Battlestar Galactica
