I'm having trouble enabling SSL with Sonarr. I followed the steps on Sonarr's wiki to create the cert/key and add the pvk file. Unfortunately, after enabling SSL and restarting, I still can't access the web page over the 9898 SSL port that's configured. I receive a "this webpage is not available" error when accessing https://10.0.0.5:9898/.
From the jail, I can see it's listening on the port:
Additionally, when I run a tcpdump, the traffic is definitely received/acknowledged on the jail
Below is the output from httpcfg -list showing it should be on port 9898
I haven't been able to find any helpful logs.
I've attempted recreating the jail/installing the plugin a few times but with the same result. Any thoughts or help would be great.
tcp4 0 0 127.0.0.1.9898 *.* LISTEN tcp4 0 0 127.0.0.1.8989 *.* LISTEN tcp4 0 0 10.0.0.5.9898 *.* LISTEN tcp4 0 0 10.0.0.5.8989 *.* LISTEN tcp4 0 0 10.0.0.5.12354 *.* LISTEN
09:08:47.269827 IP 10.0.0.110.59061 > 10.0.0.5.9898: Flags, seq 3051741438, win 65535, options [mss 1460,nop,wscale 5,nop,nop,TS val 515861234 ecr 0,sackOK,eol], length 0 09:08:47.269839 IP 10.0.0.5.9898 > 10.0.0.110.59061: Flags [S.], seq 3134178924, ack 3051741439, win 65535, options [mss 1460,nop,wscale 6,sackOK,TS val 3391431093 ecr 515861234], length 0 09:08:47.270520 IP 10.0.0.110.59061 > 10.0.0.5.9898: Flags [.], ack 1, win 4117, options [nop,nop,TS val 515861237 ecr 3391431093], length 0 09:08:47.270581 IP 10.0.0.5.9898 > 10.0.0.110.59061: Flags [F.], seq 1, ack 1, win 1023, options [nop,nop,TS val 3391431094 ecr 515861237], length 0 09:08:47.271241 IP 10.0.0.110.59061 > 10.0.0.5.9898: Flags [P.], seq 1:214, ack 1, win 4117, options [nop,nop,TS val 515861237 ecr 3391431093], length 213 09:08:47.271247 IP 10.0.0.5.9898 > 10.0.0.110.59061: Flags [R], seq 3134178925, win 0, length 0 09:08:47.271813 IP 10.0.0.110.59061 > 10.0.0.5.9898: Flags [.], ack 2, win 4117, options [nop,nop,TS val 515861237 ecr 3391431094], length 0 09:08:47.271816 IP 10.0.0.5.9898 > 10.0.0.110.59061: Flags [R], seq 3134178926, win 0, length 0 09:08:47.271817 IP 10.0.0.110.59061 > 10.0.0.5.9898: Flags [F.], seq 214, ack 2, win 4117, options [nop,nop,TS val 515861237 ecr 3391431094], length 0 09:08:47.271819 IP 10.0.0.5.9898 > 10.0.0.110.59061: Flags [R], seq 3134178926, win 0, length 0
Port: 9898 Thumbprint: 7E0F1CCF47F1CB813FA99C3077FE78B38154B6C4
