Hello!
What i've got:
1) GUI configured jail( DHCP, VNET, BPF)
2) pkg installed i2pd
3) created config i2pd.conf
4) enabled Web Console in i2pd.conf:
Everything is working but... I can't enter Web Console.
1) I2pd is working. I can see multiple connections in iftop.
2) webconsole is working on port 7070:
3) my jail ifconfig:
But when i enter http://192.168.1.15:7070 from my notebook with ip 192.186.1.20 - i've got..... NOTHING.
I've got 5 diffrent jails more. All of them - DHCP, VNET, BPF. And all of them working perfect. I can enter their ip:port and everything is OK.
Any ideas where the problem?
What i've got:
[http] ## Web Console settings ## Uncomment and set to 'false' to disable Web Console enabled = true ## Address and port service will listen on address = 127.0.0.1 port = 7070 ## Path to web console, default "/" # webroot = / ## Uncomment following lines to enable Web Console authentication # auth = true # user = i2pd # pass = changeme
root@i2pd:/ # netstat -a -n | grep LISTEN tcp4 0 0 127.0.0.1.7656 *.* LISTEN tcp4 0 0 127.0.0.1.4447 *.* LISTEN tcp4 0 0 127.0.0.1.4444 *.* LISTEN tcp4 0 0 127.0.0.1.7070 *.* LISTEN tcp4 0 0 *.22845 *.* LISTEN
root@i2pd:/ # ifconfig
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 6a:b5:99:21:6a:e1
hwaddr 02:66:f2:00:10:0b
inet 192.168.1.15 netmask 0xffffff00 broadcast 192.168.1.255
nd6 options=1<PERFORMNUD>
status: active
groups: epair
