Hi guys,
So, currently, I have a few CIFS shares setup for access to my FreeNAS plugin storage. The Dataset is called "JailStore" and I have three plugin storage locations that reside within it: MineOS, Syncthing, and Transmission. These three storage locations have been assigned a username and group associated with their plugin. IE: MineOS = mcserver, Syncthing = syncthing, Transmission = transmission. I have added each of these corresponding groups as an auxiliary member to user = "Michael" and use that to access the CIFS shares I link to the Plugin Storage.
My problem is that, When I try accessing the storage through a share located directly in the plugin storage, I am denied access. But if I try accessing the storage from a share created in the directory before it, get full read and write permissions.
Here is what happens when I try to access the storage from this particular location:
JailStore: Pass
JailStore\Syncthing: Pass
JailStore\Syncthing\Michael: Permission Denied (Strange how I could still access it via share as noted above)
JailStore\MineOS: Pass
JailStore\Transmission: Permission Denied.
This is a picture of the list of Shares I have created to test this:
here
Moreover, I have also tested the permissions of the storage using a touch test. And get the following results
JailStore: Permission Denied
JailStore\Syncthing: Denied
JailStore\Syncthing\Michael: Pass
Jailstore\MineOS: Pass
Jailstore\Transmission: Permission Denied.
Note: For the shares that are directly mounted in the plugin's storage have the aux parameter "force user = [plugin user]" and "force group = [plugin group] "
JailStore: Pass
here
