EDIT: FreeNAS-9.10-STABLE has solved the Issue!
I thought I had this issue solved awhile ago but I guess not (I don't delete files that often) but I can replicate this issue each time I copy a directory that has 48.6GB of data, delete the files using the console (which does immediately) and then I begin to receive these ctl_datamove aborted messages on the console. I have replaced all my SAS cables, and tried different LSI M1015 cards with the supported firmware version. I have also tried to copy the files from one pool to another pool, so i copy the files from my archive pool (Raidz_2_SATA) that's all SATA drives to my vmware pool (Raidz_VMware_SAS) that's all SAS drives and I run into the same issue.
These pool's live on different Supermicro chassis hardware . I currently have three LSI M1015 raid card's installed, one card for l2arc and slog, second card is for archive storage (Raidz_2_SATA) and the third raid card is for vmware storage (Raidz_VMware_SAS.)
I have also removed l2arc and slog to make sure that wasn't the issue. The current services that are running are cifs and iSCSI, but I always replicate the issue by doing the delete through the console or through CIFS. Not only do I receive the messages below, but my CPU maxes out, I lose graph information during that time and my cifs shares and ssh connections appear to be frozen.
Server: IBM x3850 X5
CPU: 4x Intel Xeon E7-4830 2.13Ghz
Memory: 1048528MB
Raid Card - 3x LSI M1015 (IT Mode)
FreeNAS-9.3-STABLE-201512121950
Memory: 1048528MB
Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1991-05.com.microsoft:desktop-g6fn6t0): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1991-05.com.microsoft:exc01.domain): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): waiting for CTL to terminate 8 tasks Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): waiting for CTL to terminate 6 tasks Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): waiting for CTL to terminate 7 tasks Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): waiting for CTL to terminate 8 tasks Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb78beb on (6:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb78bec on (6:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb78bed on (6:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb78bee on (6:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb78bef on (6:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x5f343d on (9:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x5f343e on (9:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788f8 on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788f9 on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788fa on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x8a5605 on (4:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x8a5606 on (4:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x8a5607 on (4:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x8a5608 on (4:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x8a5609 on (4:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788fb on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788fc on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788fd on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788fe on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788ff on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb78bf0 on (6:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x8a560a on (4:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb78bf1 on (6:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb78bf2 on (6:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x8a560b on (4:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5ef720 on (5:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5f343f on (9:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5ef723 on (5:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb79178 on (7:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5ef8ab on (1:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb79179 on (7:5:0) aborted Dec 23 14:19:32 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): tasks terminated Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb7a2c1 on (2:5:0) aborted Dec 23 14:19:32 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): tasks terminated Dec 23 14:19:32 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): tasks terminated Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5ef722 on (5:5:0) aborted Dec 23 14:19:32 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): tasks terminated Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb7a2c9 on (2:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5ef721 on (5:5:0) aborted <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1991-05.com.microsoft:desktop-g6fn6t0): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:20 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1991-05.com.microsoft:exc01.domain): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): waiting for CTL to terminate 8 tasks Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): waiting for CTL to terminate 6 tasks Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): waiting for CTL to terminate 7 tasks Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): waiting for CTL to terminate 8 tasks Dec 23 14:19:31 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): no ping reply (NOP-Out) after 5 seconds; dropping connection Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb78beb on (6:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb78bec on (6:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb78bed on (6:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb78bee on (6:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb78bef on (6:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x5f343d on (9:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x5f343e on (9:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788f8 on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788f9 on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788fa on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x8a5605 on (4:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x8a5606 on (4:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x8a5607 on (4:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x8a5608 on (4:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x8a5609 on (4:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788fb on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788fc on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788fd on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788fe on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb788ff on (8:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0xb78bf0 on (6:5:0) aborted Dec 23 14:19:31 <freenas_server_name> ctl_datamove: tag 0x8a560a on (4:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb78bf1 on (6:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb78bf2 on (6:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x8a560b on (4:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5ef720 on (5:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5f343f on (9:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5ef723 on (5:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb79178 on (7:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5ef8ab on (1:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb79179 on (7:5:0) aborted Dec 23 14:19:32 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx04): tasks terminated Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb7a2c1 on (2:5:0) aborted Dec 23 14:19:32 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): tasks terminated Dec 23 14:19:32 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx02): tasks terminated Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5ef722 on (5:5:0) aborted Dec 23 14:19:32 <freenas_server_name> WARNING: <ip_address> (iqn.1998-01.com.vmware:esx03): tasks terminated Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb7a2c9 on (2:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5ef721 on (5:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5ef8ba on (1:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0xb7a2d3 on (2:5:0) aborted Dec 23 14:19:32 <freenas_server_name> ctl_datamove: tag 0x5ef8ba on (1:5:0) aborted
