I found another
thread with a similar problem and the OP was asked to provide SMART logs.
There's also the same errors for another drive.
ada1
root@freenas:~ # smartctl -a -q noserial /dev/ada1
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68N32N0
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Tue Aug 22 21:09:03 2017 AEST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (45600) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 483) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 2
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 167
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 0
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 11
194 Temperature_Celsius 0x0022 122 119 000 Old_age Always - 28
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 83 -
# 2 Extended offline Completed without error 00% 8 -
# 3 Conveyance offline Completed without error 00% 0 -
# 4 Short offline Completed without error 00% 0 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ada4
root@freenas:~ # smartctl -a -q noserial /dev/ada4
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Aug 22 21:13:02 2017 AEST
was never started.
been run.
data collection: (45480) seconds.
command.
power-saving mode.
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 14
194 Temperature_Celsius 0x0022 120 119 000 Old_age Always - 30
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
In the thread I found it was suggested that SATA cables or the PSU could be the problem. I bought a box of 10 Amphenol SATA cables from eBay, same model as
these so I'm hoping they're OK.
Forgot to post earlier but specs are:
Supermicro A1SAI-2750F
2 x 8GB Crucial ECC RAM
4 x 4TB WD Reds
Seasonic G550
