Thankfully you don't sound annoyed,
Damnit, I should have tried harder to sound annoyed. I meant to sound annoyed. Just not at you.
It took me longer than it should have done to find an ftp client and log on anonymously but that is done now, and I am running it now, thank you.
It might be a bit of a "D'oh!" moment, but you have wget at your fingertips on TrueNAS.
if it did some testing of the zfs array as well as the disks individually and in parallel.
Well, in fairness, it's a tool from ... 1999? Predates ZFS.
it would be nice if it was clever enough to know to exclude the volume that was booted from (in my case I don't want to stress test a USB key ;-)
We had that problem twenty-odd years ago too. This is why there is an option to display the list of disks, and also to select a subset based on a grep.
sol.net disk array test v3
This is a nondestructive (read-only) full disk test designed to help
diagnose performance irregularities and to assist with disk burn-in
1) Use all disks (from lsblk)
2) Use selected disks (from lsblk|grep)
3) Specify disks
4) Show lsblk list
Option: 4
disk fd0
HGST_HTS725050A7E630 disk sda
HGST_HTS725050A7E630 disk sdb
HGST_HTS725050A7E630 disk sdc
HGST_HTS725050A7E630 disk sdd
HGST_HTS725050A7E630 disk sde
ST95005620AS disk sdf
HGST_HTS725050A7E630 disk sdg
HGST_HTS725050A7E630 disk sdh
Virtual_disk disk sdi
VMware_Virtual_IDE_CDROM_Drive rom sr0
Press Return:
3) Specify disks
4) Show lsblk list
Option: 2
Enter grep match pattern (e.g. ST150176): 72505
Selected disks: sda sdb sdc sdd sde sdg sdh
HGST_HTS725050A7E630 465.8G disk sda
HGST_HTS725050A7E630 465.8G disk sdb
HGST_HTS725050A7E630 465.8G disk sdc
HGST_HTS725050A7E630 465.8G disk sdd
HGST_HTS725050A7E630 465.8G disk sde
HGST_HTS725050A7E630 465.8G disk sdg
HGST_HTS725050A7E630 465.8G disk sdh
Is this correct? (y/N):
In this case the VMware Virtual Disk is the boot drive (sdi) and yes it's fair to say that there's no easy way to get the Seagate into the list (sdf) although you could search for "S" I guess.
Anyways, mapping back and forth between ZFS and the native disk identifiers on Linux and FreeBSD, which I think would require different approaches, is probably more work than I'm looking for. I am, however, continuing to see if there are small improvements to be made. I am partway through providing some in-band guidance and explanation of the various phases of the tool, and I may add a burn-in mode.
