This may seem a little crazy but please stay with me because I have really been thinking about a neat solution to my situation.
I have a server that I realize is small and somewhat inflexible. It is a Dell T110 II using the 4 main drive bays to run 4x2TB drives in a 2x2 mirror via a PCI controller card. I use one of the on-board SATA ports for the boot SSD and one (that used to run the DVD drive bay) I hope to use to run a quality removable hard-drive. I have 32GB of RAM installed.
My data volume needs are very small, not much video storage, mainly CAD/CAM files and software programming IDEs. I may never exceed the 4TB available in the mirror and if I approach this amount of data I will dump some of the video elsewhere.
My problem is adding a sensible backup system. Is it possible to run a second ZFS ZPOOL on a single removable hard-drive and use this drive to store snapshots/backups of the mirror? The plan would be to leave the single drive running full-time so that the cron replication system will work. I would actually use multiple removable drives rotating them periodically and storing the out-of-use drives securely. I am thinking of using a single 8TB drive to back up the 4TB (max) of data in the main pool.
Will this idea work and do you think that the removable drive system will work without causing a bunch of disc errors during the change-over?
Thanks, Brian
Thanks, Brian
