snapshot to second pool
ciccio
Hello. my freenas is so structured:
4 x 6tb disks
of which
3 x1raid (1 pool)
1 disk (2 pools)
how can I create the 1pool snapshot (only) on 2pool?
Thanks for your help
What you probably want to do is use a replication task with localhost as the target.
Yes. but the reply must only be in 2pool
Yes, that's called replication. You create a snapshot on the first pool, and replicate it to the second pool (which can be on the same server or somewhere totally different).
