Is it possible to have a Periodic Snapshot dedicated to a specific directory within a Dataset? It doesn't appear that there is an easy way to select a single folder, only the entire dataset.
Is the method here to create the snapshot for the dataset, and then exclude all other folders?
Scratch that, looks like exclude is only for child datasets, and not folders.
TIA - Nevermind, guess my answer is that it's all or nothing for snapshots of datasets.
