I have a volume which has a jail. I need access to a folder outside the jail (in the same volume) so I added storage to the jail.
The issue I have is that the files I want to backup with the snapshot are visible through two locations: through the volume directly and through the jail (which is also inside the volume).
I'm afraid if I create a snapshot it might backup the data twice... even though it exists once on disk. Hopefully this makes sense. Should this be a concern or am I just overthinking things?
Thanks,
-Justin
Thanks,
-Justin
