SMB Will Not Start
nmelanson75
Hi folks, I am a bit green to this type of issue as usually this works fine for me but I have a Freenas 11.2 instance that the SMB service fails to start. Can anyone provide me with any guidance on where to look at this one, I assume it is a file permission issue.
# Global parameters
[global]
bind interfaces only = Yes
deadtime = 15
disable spoolss = Yes
dns proxy = No
dos charset = CP437
hostname lookups = Yes
interfaces = 127.0.0.1 10.2.2.215
kernel change notify = No
lm announce = Yes
load printers = No
local master = No
logging = file
map to guest = Bad User
max log size = 51200
max open files = 1884773
obey pam restrictions = Yes
printcap name = /dev/null
security = USER
server min protocol = SMB2_02
server role = standalone server
smb2 leases = No
unix extensions = No
workgroup = Workgroup
idmap config * : backend = tdb
acl allow execute always = Yes
create mask = 0666
directory mask = 0777
directory name cache size = 0
dos filemode = Yes
ea support = Yes
store dos attributes = Yes
strict locking = No
System Info
FreeNAS-11.2-RELEASE-U1
Platform Intel(R) Xeon(R) CPU E3-1230 v6 @ 3.50GHz
Memory 65444MB
Supermicro System
DrKK
FreeNAS Generalissimo
what error message do you get? Is there anything in any of the relevant files in /var/log?
nmelanson75
System Info
Memory 65444MB
Supermicro System
Which log file would show SMB errors in that folder?
DrKK
Aside from /var/log/messages, you have both log.nmbd and log.smbd, I believe, in the samba4 subdirectory in var/log
nmelanson75
The messages file is quite big so I am going to rename that one to have it create a new one but here are the other two.
Big thank you for looking for me.
  • log.zip
  • smbd.txt
nmelanson75
Is it normal for /var/logs to have a virtual pointer to something like /var/db/system/syslog-a7c4a4a3d45a4720a1e6b8ad799731fd/log/
nmelanson75
Server role: ROLE_STANDALONE
# Global parameters
[global]
deadtime = 15
dns proxy = No
dos charset = CP437
lm announce = Yes
load printers = No
local master = No
logging = file
security = USER
workgroup = TV
create mask = 0666
dos filemode = Yes
ea support = Yes
strict locking = No
[Archive]
path = "/mnt/zPool/Archive"
read only = No
veto files = /.snapshot/.windows/.mac/.zfs/
vfs objects = zfs_space zfsacl streams_xattr
zfsacl:acesort = dontcare
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
[BAK.Altaro]
path = "/mnt/zPool/BAK.Altaro"
read only = No
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
[BAK.Altaro_Offsite]
path = "/mnt/zPool/BAK.Altaro_Offsite"
read only = No
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
[BAK.SQL]
path = "/mnt/zPool/BAK.SQL"
read only = No
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
[BAK.Shares]
path = "/mnt/zPool/BAK.Shares"
read only = No
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
[NET.Geo]
path = "/mnt/zPool/w.NET.Exploration"
read only = No
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
[NET.Legal]
path = "/mnt/zPool/w.NET.Legal"
read only = No
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
[NET.Share]
guest ok = Yes
path = "/mnt/zPool/w.NET.Shares"
read only = No
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
[NET.Users]
path = "/mnt/zPool/w.NET.Users"
read only = No
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
[NET.u]
access based share enum = Yes
path = "/mnt/zPool/w.NET.u"
read only = No
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
[TVnextcloudBAK]
path = "/mnt/zPool/TVnextcloudBAK"
read only = No
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
[zoftware]
path = "/mnt/zPool/zoftware"
read only = No
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
nmelanson75
root@sTVN1:~ # testparm -s --parameter-name "guest account"
Load smb config files from /usr/local/etc/smb4.conf
Processing section "[Archive]"
Processing section "[BAK.Altaro]"
Processing section "[BAK.Altaro_Offsite]"
Processing section "[BAK.SQL]"
Processing section "[BAK.Shares]"
Processing section "[NET.Geo]"
Processing section "[NET.Legal]"
Processing section "[NET.Share]"
Processing section "[NET.Users]"
Processing section "[NET.u]"
Processing section "[TVnextcloudBAK]"
Processing section "[zoftware]"
Loaded services file OK.
WARNING: You have some share names that are longer than 12 characters.
These may not be accessible to some older clients.
(Eg. Windows9x, WindowsMe, and smbclient prior to Samba 3.0.)
nobody
root@sTVN1:~ #
root@sTVN1:~ # service samba_server onerestart
Performing sanity check on Samba configuration: OK
winbindd not running? (check /var/run/samba4/winbindd.pid).
Stopping smbd.
Waiting for PIDS: 2690.
Stopping nmbd.
Waiting for PIDS: 2686.
Starting nmbd.
Starting smbd.
Starting winbindd.
root@sTVN1:~ #
nmelanson75
root@sTVN1:~ # service samba_server onestatus
nmbd is running as pid 83410.
smbd is running as pid 83415.
winbindd is not running.
root@sTVN1:~ #
root@sTVN1:~ # smbclient -NL //127.0.0.1
Anonymous login successful
Sharename Type Comment
Archive Disk
BAK.Altaro Disk
BAK.Altaro_Offsite Disk
BAK.SQL Disk
BAK.Shares Disk
NET.Geo Disk
NET.Legal Disk
NET.Share Disk
NET.Users Disk
NET.u Disk
TVnextcloudBAK Disk
zoftware Disk
IPC$ IPC IPC Service (FreeNAS Server)
Reconnecting with SMB1 for workgroup listing.
protocol negotiation failed: NT_STATUS_INVALID_NETWORK_RESPONSE
Failed to connect with SMB1 -- no workgroup available
