Currently running TrueNAS 12.0 which has been transitioned up from Freenas from 11 which was transitioned from 8.
The issue I'm having is that I can mount the smb share from my Windows devices, but I can't see all of the files in all of the directories. There are two sub-issues with this. The first is if I access the share with the non-root user, I see empty directories in 2 of the directories. If I mount the share as root, then only one of the directories appears as empty. If I ssh in as either user I'm able to see all of the directories.
One other issue, in the one directory I'm able to access as root, I run into a permissions issue on a sub-directory.
If it helps any, I'm running plex media server and the two directories with permissions issues are movies and series.
Appreciate any assistance.
