I just tested; it does work under a specific share! Now I'm running into one other issue: the GID on FreeNAS doesn't match the GID on Linux, so either I set the group to the AD-linked group and have it work on Windows and not Linux, or I set the GID to the correct one with a fake account on FreeNAS (w/ manually set GID) and it works on Linux and not Windows. Is there any chance this feature request could be implemented?
That's perfect, thanks! I was under the impression they used completely different algorithms.
Unfortunately it seems to not be working. I went to AD -> Edit idmap, set the range low to 1680000000, and set the range high to 9999999999. Despite this, `getent group db_admins` still returns `db_admins:x:21267`. Any ideas? Thanks a ton for your help.
Edit: Disable FreeNAS cache is on, and UNIX extensions are off.
Sorry for taking so long to get back; I only work at this job Mondays and Fridays. So I followed your advice and set the high to 2,000,000,000 and flushed the cache, and now I'm getting db_admins:x:90000008. That shouldn't be possible, as the range min is 1,680,000,000. Any ideas what's going on? Flushed the cache again (and by flushing the cache I mean running the 4 commands you provided) doesn't fix it.
UID 90000001 is in the range for the default idmap backend for winbind. It sounds like your idmap settings are misconfigured (or this is a trusted domain). Try removing winbindd_idmap.tdb and repeat the cache clear. (back up the idmap.tdb first).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
