SMB help with groups
kyp
hey guys, I haven't been able to find a definitive answer on if a same user and group name permission set-up for a cifs share is working?
i.e. in Windows, what I assume to be the primary group SID is not being resolved (it comes up as 'Account Unknown').
I've just rolled back to 9.10.2-U2 (from Corral).
It seems this was working in Corral / FreeBSD 11.
Note: Prior to my move to Corral, I was only using user/s, rather than groups in the smb share security permissions in Windows.
I'd appreciate some comments.
P.S: I cannot add groups that have the same name as a user (in Windows searching 'Group' object, fails to find it).
The unresolved SID is corresponding to 'net groupmap list'.
kyp
Might this be the cause?
[root@nas-1 ~]# net getdomainsid
Environment LOGNAME is not defined. Trying anonymous access.
SID for local machine NAS-1 is: S-1-5-21-495269793-4130344135-2154332175
Could not fetch domain SID
[root@nas-1 ~]#
[root@nas-1 ~]#
[root@nas-1 ~]# net groupmap list
xxxx (S-1-5-21-4272316903-4045912713-2756313090-1002) -> xxxx
[root@nas-1 ~]#
I thought this sort of mismatch was resolved?
The strange thing is that I did a fresh install and re-created all my users and groups.
UPDATE: I managed to fix using 'net groupmap delete' and then 'net groupmap add' to re-create.
anodos
Sambassador
It works, but from an administrative standpoint it is bad practice to do things that way on a FreeNAS samba server (i.e. when you're using zfsacls). This is because you will typically administer permissions on your server via "File Explorer" on a Windows computer and it may not be immediately obvious whether you're dealing with a user or a group object when you are looking at the ACL. On the backend, the user and group should each have a different SID.
anodos
Sambassador
@Ericloewe can you please move posts 9-12 to a new thread if it's possible?
@kyp What was the procedure you used to roll back to 9.10.2-U2. It looks like your freenas server generated a new domain SID, but retained the old GID/UID -> SID mappings. This is a rather tricky problem to work around, and it's been a year or more since I had to tackle it. There is a python script that is supposed to fix the problem, but it might not work on 9.10.2-U2. Please provide as much detail as possible how you rolled back. I assume at some point you applied an old config file?
kyp
Thanks for the reply anodos.
I did have old config files, but decided to re-configure everything from scratch so it's quite strange.
Yeah, this is something I already encountered as a problem.
I'm now thinking of creating a new user/group concept.
Sorry, mess up this thread - you can move this post as well.
anodos
Sambassador
No problem. To be clear, on the surface you actually do have a problem. It looks like the samba groupmap is in a broken state due to the downgrade from Corral. This is an issue that should probably reported as a bug so that a proper "fix" procedure can be put in place.
Note: the above comment was wrong. No problem with group map as far as I can tell. I'm leaving post intact to preserve context.
kyp
Aren't the group mappings done based on creation of users/groups and whether you define the user to be a Microsoft account?
i.e. nothing to do with the volume, that I imported into 9.10.2-U2 environment.
Atm, I'm having trouble adding a group to the share from Windows - trying to figure it out.
anodos
Sambassador
Well, the group mappings are stored in a tdb file that might have been preserved when you downgraded from 10 -> 9 (the tdb is stored in your zpool). Run the following command on your FreeNAS server: fixsid.py Post the output.
kyp
[root@nas-1 ~]# fixsid.py
detected SID: S-1-5-21-495269793-4130344135-2154332175
database SID: None
Saving detected SID to the database
Please either reboot the system or run the following commands as root:
service samba_server stop
service ix-pre-samba start
service samba_server start
[root@nas-1 ~]#
I now stopped/started the samba service.
When I try to add the group from Windows, it adds it, then starts applying it recursively to files/folders, but then it disappears.
kyp
Refer to attachment.
'sysadmin' is the owner (user) and 'nogroup' is the owner (group) for dataset 'mediavault'.
I'm trying to add 'users' group to the share security from Windows.
anodos
Sambassador
Upload a debug file "system" -> "advanced" -> "save debug". If you're concerned about private data, send me it in a PM.
anodos
Sambassador
It looks like you're trying to set permissions for the well-known group "Users" in the Windows world. S-1-5-32-545 This isn't generated in the default FreeNAS group mapping. Try creating a group in the FreeNAS UI and then assigning permissions to it.
kyp
Thanks anodos, I had created "users" via the FreeNAS GUI.
I notice that when you create this group, a groupmap is automatically added.
i.e. 'net groupmap list' - has ntgroup to unix group mapping, with an assigned SID that's different to the standard SID in the Windows world.
P.S: When I search for groups to add from Windows, I'm only searching for groups/users on freenas.
anodos
Sambassador
Interesting. What happens if you use a group that isn't "users", I.e. " samba_users"?
kyp
hey anodos, that worked!
Thanks for your time and effort.
Lessons:
  1. Do not set up user name = group name (and UID = GID) for a smb server, it seems Windows cannot distinguish b/w user and group. Do you know why this would be the case? I would expect SIDs to be different and this is all that Windows should be interested in.
  2. Do not name your group "users" - Windows gets confused (even if you explicitly browse the freenas users/groups)
anodos
Sambassador
Lessons:
I think (2) is most likely what really tripped you up.
To be a bit clearer. Windows has certain expectations regarding built-in groups such as S-1-5-32-545 [BUILTIN\users]. I.e., that it exists. Samba satisfies this by automatically generating a groupmap entry Users (S-1-5-32-545) -> BUILTIN\users. It also does the same for "Administrators".
Some group names to avoid using on samba shares are as follows
  • Access Control Assistance Operators
  • Administrators
  • Backup Operators
  • Cryptographic Operators
  • Distributed COM Users
  • Event Log Readers
  • Guests
  • Hyper-V Administrators
  • Network Configuration Operators
  • Power Users
  • Remote Desktop Users
  • Remote Management Users
  • Replicator
  • System Managed Accounts Group
  • Users
By no means is this complete. It's important to realize that you FreeNAS samba server is trying to be a Windows server. It's best to respect Windows expectations regarding group / user names.
kyp
Thanks, that makes sense.
I don't think it's an issue
Hmm, how do you then explain the Windows confusion?
e.g. when attempting to add group "blah" to the share from Windows, it reverts to user "blah".
anodos
Sambassador
Lessons:
One further comment regarding (2). I just created a group "Users" on my freenas server, and it appears as an available group. Unfortunately, there are two "Users" entries without an easy way to differentiate between them. You probably selected the first entry, which is BUILTIN\Users, rather than FREENAS\Users. Since windows looks primarily at SIDs, you're probably okay to use "users", but I still wouldn't trust it.
