Hi all, we recently upgraded from 13.0-U3.1 to 13.0-U6.1; after this upgrade, our SMB seems very broken. The service does seem to run:
But attempting to connect over SMB results in the connection simply timing out, with no further information.
I don't see anything suspicious in
Any idea what's going on?
Edit: Since I was a dumb-dumb and posted this to the archives instead of the main forums I can't reply.
Unfortunately using 127.0.0.1 didn't work, it also times out. Here's the output, along with the output of
root@server[~]# service smbd status smbd is running as pid 2622. root@server[~]# smbstatus Samba version 4.15.13 PID Username Group Machine Protocol Version Encryption Signing ---------------------------------------------------------------------------------------------------------------------------------------- Service pid Machine Connected at Encryption Signing --------------------------------------------------------------------------------------------- No locked files
root@server[~]# smbclient -L //<server_ip> -U jmy1000 -d 3 lp_load_ex: refreshing parameters Initialising global parameters Processing section "[global]" added interface ix1 ip=<server_ip> bcast=<xx.xx.xx>.255 netmask=255.255.254.0 Client started (version 4.15.13). Connecting to <server_ip> at port 445 protocol negotiation failed: NT_STATUS_IO_TIMEOUT root@server[~]# midclt call smb.status AUTH_LOG | jq []
/var/log/messages, or in /var/log/samba4:Code:
root@server[~]# cat /var/log/samba4/log.smbd [2024/01/03 00:22:42.682625, 0] ../../source3/smbd/server.c:1734(main) smbd version 4.15.13 started. Copyright Andrew Tridgell and the Samba Team 1992-2021 [2024/01/03 00:22:42.693011, 1] ../../source3/profile/profile.c:55(set_profile_level) INFO: Profiling turned OFF from pid 3623 [2024/01/03 00:22:43.087634, 1] ../../source3/smbd/files.c:811(file_init_global) file_init_global: Information only: requested 3771576 open files, 59392 are available. [2024/01/03 00:47:21.143465, 0] ../../source3/smbd/server.c:1734(main) smbd version 4.15.13 started. Copyright Andrew Tridgell and the Samba Team 1992-2021 [2024/01/03 00:47:21.153232, 1] ../../source3/profile/profile.c:55(set_profile_level) INFO: Profiling turned OFF from pid 4319 [2024/01/03 00:47:21.505445, 1] ../../source3/smbd/files.c:811(file_init_global) file_init_global: Information only: requested 3771576 open files, 59392 are available. [2024/01/03 00:52:00.467408, 0] ../../source3/smbd/server.c:1734(main) smbd version 4.15.13 started. Copyright Andrew Tridgell and the Samba Team 1992-2021 [2024/01/03 00:52:00.477144, 1] ../../source3/profile/profile.c:55(set_profile_level) INFO: Profiling turned OFF from pid 4578 [2024/01/03 00:52:00.833740, 1] ../../source3/smbd/files.c:811(file_init_global) file_init_global: Information only: requested 3771576 open files, 59392 are available. [2024/01/03 01:06:44.478847, 0] ../../source3/smbd/server.c:1734(main) smbd version 4.15.13 started. Copyright Andrew Tridgell and the Samba Team 1992-2021 [2024/01/03 01:06:44.489788, 1] ../../source3/profile/profile.c:55(set_profile_level) INFO: Profiling turned OFF from pid 5013 [2024/01/03 01:06:44.858269, 1] ../../source3/smbd/files.c:811(file_init_global) file_init_global: Information only: requested 3771576 open files, 59392 are available. [2024/01/03 01:15:14.288915, 0] ../../source3/smbd/server.c:1734(main) smbd version 4.15.13 started. Copyright Andrew Tridgell and the Samba Team 1992-2021 [2024/01/03 01:15:14.298831, 1] ../../source3/profile/profile.c:55(set_profile_level) INFO: Profiling turned OFF from pid 5401 [2024/01/03 01:15:14.654848, 1] ../../source3/smbd/files.c:811(file_init_global) file_init_global: Information only: requested 3771576 open files, 59392 are available. [2024/01/03 01:25:03.094936, 0] ../../source3/smbd/server.c:1734(main) smbd version 4.15.13 started. Copyright Andrew Tridgell and the Samba Team 1992-2021 [2024/01/03 01:25:03.141834, 1] ../../source3/profile/profile.c:55(set_profile_level) INFO: Profiling turned OFF from pid 2620 [2024/01/03 01:25:03.561780, 1] ../../source3/smbd/files.c:811(file_init_global) file_init_global: Information only: requested 3771576 open files, 59392 are available. [2024/01/03 01:25:03.667215, 0] ../../source3/smbd/server.c:1734(main) smbd version 4.15.13 started. Copyright Andrew Tridgell and the Samba Team 1992-2021 [2024/01/03 01:25:03.675469, 1] ../../source3/profile/profile.c:55(set_profile_level) INFO: Profiling turned OFF from pid 2640
testparm -s:Code:
root@server[~]# smbclient -L //127.0.0.1 -U jmy1000 -d 3
Connecting to 127.0.0.1 at port 445
root@server[~]# testparm -s
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Weak crypto is allowed
Server role: ROLE_STANDALONE
# Global parameters
[global]
aio max threads = 2
bind interfaces only = Yes
disable spoolss = Yes
dns proxy = No
enable web service discovery = Yes
kernel change notify = No
load printers = No
logging = file
map to guest = Bad User
max log size = 5120
registry shares = Yes
server multi channel support = No
server role = standalone server
unix extensions = No
fruit:nfs_aces = No
rpc_server:mdssvc = disabled
rpc_daemon:mdssd = disabled
idmap config * : backend = tdb
directory name cache size = 0
dos filemode = Yes
[cookie]
comment = Main server share
ea support = No
kernel share modes = No
path = /mnt/server/club
posix locking = No
read only = No
smbd max xattr size = 2097152
vfs objects = fruit streams_xattr shadow_copy_zfs ixnas zfs_core aio_fbsd
fruit:resource = stream
fruit:metadata = stream
nfs4:chown = true
ixnas:dosattrib_xattr = false
[vm-alpine]
ea support = No
path = /mnt/server/Virtual Machines
posix locking = No
read only = No
nfs4:chown = true
[signup]
browseable = No
comment = Holds Utility for Account Registration
ea support = No
guest ok = Yes
mangled names = no
path = /mnt/server/clubsignup
read only = No
vfs objects = audit catia fruit streams_xattr ixnas
fruit:encoding = native
nfs4:chown = true
