NFS Shares listed instead of SMB
ericfoss
I'm running TrueNAS-SCALE-22.02.0 and for some reason my NFS shares are listed when viewing server in Windows 10 file explorer. If I stop the NFS service, the server disappears from Windows. How could NFS shares be seen in Windows?
sudo showmount -e localhost​
Export list for localhost:
/mnt/local-raid/nfs *
/mnt/local-raid/cloud 192.168.1.16
smbclient -L \\\\192.168.1.10​
protocol negotiation failed: NT_STATUS_CONNECTION_DISCONNECTED
tail /var/log/samba4/log.smbd​
[2022/02/23 14:00:43, 1] ../../lib/param/loadparm.c:1766(lpcfg_do_global_parameter)
lpcfg_do_global_parameter: WARNING: The "syslog only" option is deprecated
[2022/02/23 14:00:43.796252, 0] ../../source3/smbd/server.c:1734(main)
smbd version 4.15.5-TrueNAS started.
Copyright Andrew Tridgell and the Samba Team 1992-2021
[2022/02/23 14:00:43.797437, 1] ../../lib/param/loadparm.c:1766(lpcfg_do_global_parameter)
[2022/02/23 14:00:43.801232, 1] ../../source3/profile/profile.c:54(set_profile_level)
INFO: Profiling turned OFF from pid 481116
[2022/02/23 14:00:43.817478, 0] ../../source3/smbd/server.c:1082(smbd_open_one_socket)
smbd_open_one_socket: open_socket_in failed: Address already in use
[2022/02/23 14:00:43.817673, 0] ../../source3/smbd/server.c:1082(smbd_open_one_socket)
ericfoss
Well, I don't know how to check, but `get-nfsshare` is not a known cmdlet. Does that mean I haven't enabled it?
jgreco
Resident Grinch
You'd have to ask your local Windows washers. I don't really do Windows. You asked how NFS shares could be seen in Windows, which is an odd question that occasionally pops up here because apparently almost nobody knows that Windows supports NFS. But the details are left as an exercise to the reader, at which point you'll know more about it than I.
Are you using Windows 10 Pro? I don't believe this is available with the Home Edition.
Either way, you can check (or disable):
Control Panel -> Programs and Features -> Turn Windows features on or off -> Locate "NFS Services" or "Services for NFS" -> uncheck it
ericfoss
This is news to me and seems to be part of my problem. With winnielinnie's help I did uninstall the client feature and booted into Ubuntu. I still can't connect to the smb shares, but at least I'm not wondering why I'm seeing NFS.
