smb file transfer fail. goes to 0 and pauses/stops.
mikola
Hello guys,
Im sorry im really new to this. I installed the recent truenas scale system on an old computer and wanted to use it as a file storage.
It seems to be working fine on a local network using a mirror system. all the hdd/system tests come out successful.
However if i try to transfer files using smb/tailscale in a few seconds it either pauses or stops completely.
I am aware you should have 8gb ram on the system according to reccomendations and i only have 4 at the moment. But before investing into an old machine i want to make sure thats the problem. Somehow i want to believe 4gb should be enough to make a simple file transfer?
I could not find anything online that would help me actually find which parts of software/hardware could be causing this ?
maybe somebody could put me on the right track on to find the fault ? :)
System:
CPU
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Model name: AMD A4-7300 APU with Radeon HD Graphics
Base Board Information
Manufacturer: ASRock
Product Name: FM2A88M-HD+
Version:
Serial Number: M80-43020501572
RAM
1x Size: 4 GB
PC3-12800 (800 MHz)
DDR3 1600MHz
HDD
2x HUS726040ALN610 4TB 6Gbps 7.2K RPM 4Kn Enterprise SATA HDD
Intel SSDSC2BW120A401 120GB SATA SSD
SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7801] (rev 40)
IDE interface [0101]: Advanced Micro Devices, Inc. [AMD] FCH IDE Controller [1022:780c]
Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 0b)
Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8169 PCI Gigabit Ethernet Controller [10ec:8169] (rev 10)
Its either zero or this (but usually eventually it just stops alltogether)
Then it says this:
Windows error code 0x8007003b prevents you from copying your files to your intended network location.
All system part reports just look like spikes during the envent.
1x Size: 4 GB
That's not nearly enough memory. The absolute lowest you can expect to go is 8 GB, and 16 GB really should be the starting point for any real system.
There's a lot here that is actively detrimental to performance. Besides having very little RAM, and only a single channel, the CPU is pretty weak and the NIC is terrible.
