SOLVED smb/cifs not accessible after update
heffjos
I updated from FreeNAS-9.3-STABLE-201501212031 to FreeNAS-9.3-STABLE-201502162250 using the GUI. My shares are no longer available on my Windows machines. I can log in through ssh and the web gui. If I boot from the previous version, the shares are again accessible.
Nothing was changed in the CIFS share options. I included screenshots of my CIFS screens. I ran testparm and see not problems either. I also included the last 100 lines of /var/log/messages.
Any help would be appreciated.
  • testparm.txt
  • messages.txt
djonik1562
I have same problem too. On FreeNAS-9.3-STABLE-201502110455 good work. After update to FreeNAS-9.3-STABLE-201502162250 or FreeNAS-9.3-STABLE-201502210408 sharing don't work. I must rollback on FreeNAS-9.3-STABLE-201502110455 after update and charing working. Please, help.
rogerh
CIFS sharing to Mac and Windows 8 is working in 201502162250 for me. But my WINS server (a somewhat flaky version of SAMBA on SuSE 11.4) does not seem to be advertising my FreeNAS CIFS shares so I need to actually open \\<netbios-name-of-FreeNAS>\ in an explorer window to find them.
Osiris
My newbish 2 cents:
What do you mean by "sharing doesn't work" ? You say your shares are no longer available.
Are they actually even when accessed from winX via \\nas-ip\share or are you getting the good ol'e Error 13 Permission Denied when connecting to them ?
If so, it's a known (windows) bug which I encountered when connecting to cifs after a freenas upgrade.
Change your cifs password to something else & then back to the same & retry.
Could you post the content of
/usr/local/etc/smb4.conf
djonik1562
Sharing doesn't work - on my network i can't see freenas. I try open \\nas-ip - not opened. Thinking, thinking and doesn't open.
heffjos
Same thing is happening to me. In explorer, if I type \\nas-ip it times out and pops up with "Windows cannot access \\nas-ip". Here is a screenshot of the remaining message:
When I try to troubleshoot the problem in Windows, it comes up with this error:
I changed my user password for both my Windows and FreeNAS machines, but I still cannot connect to CIFS shares from my Windows machines. I also tried booting from a fresh install of FreeNAS on a different USB, but I still couldn't access the CIFS shares. I may try this option again, because there were other problems that were also happening when I did this. Everything still works with 201501212031 on the original USB. I attached /usr/local/etc/smb4.conf file and the past couple days of /var/log/samba4/log.smbd. Where would the error 13 show, in /var/log/messages?
  • log2.smbd.txt
  • smb4.conf.txt
D
dlavigne
Guest
Please create a bug report at bugs.freenas.org and post the issue number here.
You should attach a debug file to this thread too...
djonik1562
I now updated to FreeNAS-9.3-STABLE-201502232343, but CIFS don't working, Rollback on FreeNAS-9.3-STABLE-201502110455.
What debug file? In CIFS set log to debug and get debug file?
SweetAndLow
Sweet'NASty
It's a button in the GUI. Sorry I don't remember where it's at but I'm sure you can find it.
djonik1562
Debug from GUI. When freenas running, sharing thinking, thinking. When freenas i rebooted, then error "Connection problem".
  • debug-djoniknas-20150225203502.tgz
heffjos
Just an update, a solution was found. I had to add the line "127.0.0.1 mymachinename mymachinename.domain.name" without quotes to /etc/hosts file.
