SofaKingBoring
- Mar 24, 2023
Hi Guys,
After getting my VLANs setup with the help of THIS thread here, it worked fine for as long as my client stayed in the same VLAN.
As described in the other thread I have 2 VLANs in use currently "Server/101" and "Client/102".
While setting TrueNAS up I used a management client in 101, as I usually do.
So now I have started to use a client from 102 and I'm getting the following strange behaviour:
GUI drops every 1-2 Minutes and shows "waiting for controller to come up" and then returns without having to log in again. So no timeout here.
Even worse is the SMB behaviour: In more or less the same intervall maybe even more often it hangs. So browsing in folders is a huge pain.
Copying files may give the best hint.
Windows explorer shows the "0% copied, preparing copying" window forever. Even for the tiniest file.
In the background the file gets copied and appears after refreshing, but I have to cancel the copy job in the foreground at 0%.
In my router/firewall (OPNsense) ports 80/443 are open.
I have also opened ports 111,137,138,139,445,2049,548 for filesharing, although I won't need a few of those eventually.
It's not a performance issue in OPNsense, or at least not CPU/Mem/Bandwidth.
Currently my client are on the same L2 switch for testing purposes (Unifi Flex Mini) but ports cannot talk to each other and traffic has to go to core switch (USW-24 gen 2, also L2). Behind that sits the firewall.
As soon I am on the same VLAN, everything is working perfectly of course.
Any ideas?
Any ideas?
