smartd Daemon and unreadable sector reports
Cainram
I'm running FreeNAS-9.2.1.7-RELEASE-x64 (fdbe9a0) on an Intel(R) Xeon(R) CPU X3470 @ 2.93GHz with 16GB of ECC RAM. I have two Crucial SSDs in a mirror.
I got two emails from the machine with the following information:
Email One:
The following warning/error was logged by the smartd daemon:
Device: /dev/ada0, 1 Currently unreadable (pending) sectors
Device info:
Crucial_CT960M500SSD1, S/N:14240C513F6F, WWN:5-00a075-10c513f6f, FW:MU05, 960 GB
Email Two:
Device: /dev/ada1, 1 Currently unreadable (pending) sectors
Device info:
Crucial_CT960M500SSD1, S/N:14240C513F81, WWN:5-00a075-10c513f81, FW:MU05, 960 GB
These emails were both generated six minutes after the scheduled beginning of a scrub.
However, when I view the SMART data from the CLI, I see this:
[root@tcdocs] ~# smartctl -a /dev/ada0
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p10 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: Crucial_CT960M500SSD1
Serial Number: 14240C513F6F
LU WWN Device Id: 5 00a075 10c513f6f
Firmware Version: MU05
User Capacity: 960,197,124,096 bytes [960 GB]
Rotation Rate: Solid State Device
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 6
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Feb 2 11:25:41 2015 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: ( 1105) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 74) minutes.
Conveyance self-test routine
recommended polling time: ( 3) minutes.
SCT capabilities: (0x0035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 100 100 000 Pre-fail Always - 0
5 Reallocated_Sector_Ct 0x0033 100 100 000 Pre-fail Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 3018
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2
171 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
172 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
173 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
174 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 1
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033 000 000 000 Pre-fail Always - 16523
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 068 058 000 Old_age Always - 32 (0 42 0 0 0)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
202 Unknown_SSD_Attribute 0x0031 100 100 000 Pre-fail Offline - 0
206 Unknown_SSD_Attribute 0x000e 100 100 000 Old_age Always - 0
210 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
246 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 1534556012
247 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 48375171
248 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 61693756
SMART Error Log Version: 1
No Errors Logged
# 1 Vendor (0xff) Completed without error 00% 2762 -
# 2 Extended offline Completed without error 00% 2732 -
# 3 Vendor (0xff) Completed without error 00% 2721 -
# 4 Extended offline Completed without error 00% 1989 -
# 5 Vendor (0xff) Completed without error 00% 690 -
# 6 Vendor (0xff) Completed without error 00% 678 -
# 7 Vendor (0xff) Completed without error 00% 476 -
# 8 Vendor (0xff) Completed without error 00% 446 -
# 9 Vendor (0xff) Completed without error 00% 386 -
#10 Vendor (0xff) Completed without error 00% 363 -
#11 Vendor (0xff) Completed without error 00% 341 -
#12 Vendor (0xff) Completed without error 00% 319 -
#13 Vendor (0xff) Completed without error 00% 297 -
#14 Vendor (0xff) Completed without error 00% 279 -
#15 Vendor (0xff) Completed without error 00% 261 -
#16 Vendor (0xff) Completed without error 00% 237 -
#17 Vendor (0xff) Completed without error 00% 219 -
#18 Vendor (0xff) Completed without error 00% 197 -
#19 Vendor (0xff) Completed without error 00% 177 -
#20 Vendor (0xff) Completed without error 00% 154 -
#21 Vendor (0xff) Completed without error 00% 132 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@tcdocs] ~# smartctl -a /dev/ada1
Serial Number: 14240C513F81
LU WWN Device Id: 5 00a075 10c513f81
Local Time is: Mon Feb 2 11:25:44 2015 CST
been run.
data collection: ( 2270) seconds.
command.
power-saving mode.
194 Temperature_Celsius 0x0022 068 057 000 Old_age Always - 32 (0 43 0 0 0)
246 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 1534556020
247 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 48375187
248 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 59834909
No Errors Logged
# 1 Vendor (0xff) Completed without error 00% 2763 -
# 3 Vendor (0xff) Completed without error 00% 2722 -
# 5 Vendor (0xff) Completed without error 00% 689 -
# 6 Vendor (0xff) Completed without error 00% 677 -
# 7 Vendor (0xff) Completed without error 00% 473 -
# 8 Vendor (0xff) Completed without error 00% 443 -
# 9 Vendor (0xff) Completed without error 00% 383 -
#10 Vendor (0xff) Completed without error 00% 362 -
#11 Vendor (0xff) Completed without error 00% 340 -
#12 Vendor (0xff) Completed without error 00% 316 -
#13 Vendor (0xff) Completed without error 00% 295 -
#14 Vendor (0xff) Completed without error 00% 275 -
#15 Vendor (0xff) Completed without error 00% 257 -
#16 Vendor (0xff) Completed without error 00% 235 -
#17 Vendor (0xff) Completed without error 00% 217 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
I don't see anything regarding unreadable sectors. I also find it odd that both drives generated the same error at the same time. What does this mean? It seems from everything I know about the SMART data (which admittedly isn't much), the drives seem fine. If anyone would like to chime in, I'm all ears. Thanks in advance.
Well, "unknown attribute" 174 shows a non-zero value. It could be that the drive remapped it as a result of the scrub and that 174 indicates some kind of remapping. Other than that, I have zero clue. You'd have to ask Crucial for more info unfortunately. :(
I believe CrystalDiskInfo can decode those unknown attributes. If possible, try reading the SMART data with it on a PC.
Crystaldiskinfo kind of scares me because I've found several occasions where it was totally wrong about "unknown attributes". Anything listed as an "unknown attribute" should only be "interpreted" by the manufacturer of the disk.
