JKman
- Mar 23, 2014
below are my smartctl results on a drive. i assume this means the drive is likely to fail soon and i need to replace. can someone confirm please? if there is a way to correct these issues as well i am all ears.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Toshiba 3.5" DT01ACA... Desktop HDD
Device Model: TOSHIBA DT01ACA300
Serial Number: 93845KJKS
LU WWN Device Id: 5 000039 ff4cffde1
Firmware Version: MX6OABB0
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Wed Mar 18 02:00:01 2020 MST
SMART support is: Enabled
Power mode is: ACTIVE or IDLE
1 Raw_Read_Error_Rate 0x000b 085 085 016 Pre-fail Always - 10027130
2 Throughput_Performance 0x0005 140 140 054 Pre-fail Offline - 68
3 Spin_Up_Time 0x0007 130 130 024 Pre-fail Always - 440 (Average 441)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 50
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 117 117 020 Pre-fail Offline - 36
9 Power_On_Hours 0x0012 094 094 000 Old_age Always - 47426
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 50
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 210
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 210
194 Temperature_Celsius 0x0002 171 171 000 Old_age Always - 35 (Min/Max 22/81)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 8
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 25 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 25 occurred at disk power-on lifetime: 47394 hours (1974 days + 18 hours)
ER ST SC SN CL CH DH
40 51 08 38 3e bb 07 Error: UNC at LBA = 0x07bb3e38 = 129711672
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 28 80 00 45 77 40 00 3d+06:43:56.473 READ FPDMA QUEUED
60 08 78 38 3e bb 40 00 3d+06:43:56.473 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 3d+06:43:56.469 READ LOG EXT
61 50 68 58 9c b3 40 00 3d+06:43:54.008 WRITE FPDMA QUEUED
61 50 60 00 9c b3 40 00 3d+06:43:54.005 WRITE FPDMA QUEUED
Error 24 occurred at disk power-on lifetime: 47394 hours (1974 days + 18 hours)
40 51 08 38 3e bb 07 Error: WP at LBA = 0x07bb3e38 = 129711672
61 50 58 48 9b b3 40 00 3d+06:43:54.001 WRITE FPDMA QUEUED
61 50 50 40 9a b3 40 00 3d+06:43:53.997 WRITE FPDMA QUEUED
61 58 48 30 98 b3 40 00 3d+06:43:53.993 WRITE FPDMA QUEUED
Error 23 occurred at disk power-on lifetime: 47394 hours (1974 days + 18 hours)
60 28 00 00 45 77 40 00 3d+06:43:49.485 READ FPDMA QUEUED
60 08 f8 38 3e bb 40 00 3d+06:43:49.485 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 3d+06:43:49.481 READ LOG EXT
60 28 e8 00 45 77 40 00 3d+06:43:45.974 READ FPDMA QUEUED
60 08 e0 38 3e bb 40 00 3d+06:43:45.974 READ FPDMA QUEUED
Error 22 occurred at disk power-on lifetime: 47394 hours (1974 days + 18 hours)
2f 00 01 10 00 00 00 00 3d+06:43:45.970 READ LOG EXT
60 28 d0 00 45 77 40 00 3d+06:43:42.422 READ FPDMA QUEUED
60 08 c8 00 41 77 40 00 3d+06:43:42.422 READ FPDMA QUEUED
Error 21 occurred at disk power-on lifetime: 47394 hours (1974 days + 18 hours)
60 08 c0 d8 84 bb 40 00 3d+06:43:42.402 READ FPDMA QUEUED
60 08 b8 38 3e bb 40 00 3d+06:43:42.391 READ FPDMA QUEUED
60 18 b0 e8 40 77 40 00 3d+06:43:42.388 READ FPDMA QUEUED
