smartctl long test - scsi error
moosport2
Building a new server using 4x HSGT 3.5" SAS drives. All drives returns the below error when trying to run smartctl long test.
Short test works without issue. HBA is SAS3008 in IT mode on firmware version 16.0.17
googling for not yield much result to solve the issue.
Long (extended) offline self test failed [unsupported field in scsi command]
Jailer
Not strong, but bad
The error tells you what you need to know, the long test is unsupported. Not uncommon for SAS drives to have limited SMART support.
