SMART test on failing drive clears errors?
M3PH
So heres a curious one: I have a drive that last night was marked as unhealthy. I already knew it was failing and had ordered a new one yesterday (so don't panic. It's in the post) but to be sure I ran a long smart test on it overnight. the drive had 360 unreadable (pending sectors) and had developed 96 write errors during the course of the day. I wake up this morning and I check the results. The test was aborted but the drive is now marked as ok. Did the smart test just move the data in the bad sectors to a good spot? were the errors a false negative? what happened? anyone got any ideas?
here's the smartctl data
Model Family:     Seagate BarraCuda 3.5 (SMR)
Device Model:     ST2000DM008-2FR102
Serial Number:    ZFL0205V
LU WWN Device Id: 5 000c50 0b38a38bf
Firmware Version: 0001
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
TRIM Command:     Available
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Mar 12 13:55:12 2024 GMT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
Self-test execution status:      (  41) The self-test routine was interrupted
                                        by the host with a hard or soft reset.
data collection:                (    0) seconds.
capabilities:                    (0x73) SMART execute Offline immediate.
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 199) minutes.
Conveyance self-test routine
SCT capabilities:              (0x30a5) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   045   042   006    Pre-fail  Always       -       58547401
  3 Spin_Up_Time            0x0003   098   097   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       767
  5 Reallocated_Sector_Ct   0x0033   085   085   010    Pre-fail  Always       -       40688
  7 Seek_Error_Rate         0x000f   091   060   045    Pre-fail  Always       -       1264598562
  9 Power_On_Hours          0x0032   050   050   000    Old_age   Always       -       44294h+40m+29.304s
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       642
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   095   095   000    Old_age   Always       -       5
188 Command_Timeout         0x0032   100   092   000    Old_age   Always       -       248 248 1376
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   071   058   040    Old_age   Always       -       29 (Min/Max 27/31)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       709
193 Load_Cycle_Count        0x0032   001   001   000    Old_age   Always       -       243788
194 Temperature_Celsius     0x0022   029   042   000    Old_age   Always       -       29 (0 13 0 0 0)
195 Hardware_ECC_Recovered  0x001a   078   064   000    Old_age   Always       -       58547401
197 Current_Pending_Sector  0x0012   099   099   000    Old_age   Always       -       352
198 Offline_Uncorrectable   0x0010   099   099   000    Old_age   Offline      -       352
199 UDMA_CRC_Error_Count    0x003e   200   138   000    Old_age   Always       -       20473620
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       18202h+42m+03.532s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       42027016137
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       38464112865
SMART Error Log Version: 1
ATA Error Count: 5
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 5 occurred at disk power-on lifetime: 28060 hours (1169 days + 4 hours)
  ER ST SC SN CL CH DH
  40 51 00 ff ff ff 0f  Error: UNC at LBA = 0x0fffffff = 268435455
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 00 00 ff ff ff 4f 00      00:11:37.423  READ FPDMA QUEUED
  60 00 00 ff ff ff 4f 00      00:11:37.149  READ FPDMA QUEUED
  60 00 00 ff ff ff 4f 00      00:11:37.146  READ FPDMA QUEUED
Error 4 occurred at disk power-on lifetime: 28060 hours (1169 days + 4 hours)
  40 51 00 68 d2 7c 0a  Error: UNC at LBA = 0x0a7cd268 = 175952488
  60 00 00 00 d3 7c 4a 00      00:10:37.051  READ FPDMA QUEUED
  60 00 00 00 d2 7c 4a 00      00:10:37.050  READ FPDMA QUEUED
  06 01 01 00 00 00 e0 00      00:10:37.049  DATA SET MANAGEMENT
  60 00 00 00 d1 7c 4a 00      00:10:36.850  READ FPDMA QUEUED
  60 00 00 00 d0 7c 4a 00      00:10:36.849  READ FPDMA QUEUED
Error 3 occurred at disk power-on lifetime: 28060 hours (1169 days + 4 hours)
  40 51 00 38 cb 7c 0a  Error: UNC at LBA = 0x0a7ccb38 = 175950648
  60 00 00 00 cb 7c 4a 00      00:10:35.763  READ FPDMA QUEUED
  60 00 00 00 ca 7c 4a 00      00:10:35.763  READ FPDMA QUEUED
  60 00 00 00 c9 7c 4a 00      00:10:35.761  READ FPDMA QUEUED
  60 00 00 00 c8 7c 4a 00      00:10:35.760  READ FPDMA QUEUED
  60 00 00 00 c7 7c 4a 00      00:10:35.753  READ FPDMA QUEUED
Error 2 occurred at disk power-on lifetime: 24417 hours (1017 days + 9 hours)
  60 00 00 ff ff ff 4f 00      00:07:14.650  READ FPDMA QUEUED
  60 00 00 ff ff ff 4f 00      00:07:14.647  READ FPDMA QUEUED
  60 00 00 ff ff ff 4f 00      00:07:14.644  READ FPDMA QUEUED
Error 1 occurred at disk power-on lifetime: 21208 hours (883 days + 16 hours)
  40 51 00 f0 ef 0f 0a  Error: UNC at LBA = 0x0a0feff0 = 168816624
  60 00 00 00 ef 0f 4a 00   1d+03:36:00.624  READ FPDMA QUEUED
  60 00 00 00 ee 0f 4a 00   1d+03:36:00.624  READ FPDMA QUEUED
  60 00 00 00 ed 0f 4a 00   1d+03:36:00.621  READ FPDMA QUEUED
  60 00 00 00 ec 0f 4a 00   1d+03:36:00.621  READ FPDMA QUEUED
  60 00 00 00 eb 0f 4a 00   1d+03:36:00.618  READ FPDMA QUEUED
# 1  Extended offline    Interrupted (host reset)      90%     44285         -
# 2  Short offline       Completed without error       00%     44236         -
M3PH
looking at the data, i'm assuming coz it's an smr drive, the errors were because of the write around delay (or what ever that term is) and the smart test gave it a kick, which caused the drive to sort itself out
chuck32
The new one is a CMR drive? You should consider replacing all your SMR drives with CMR drives.
M3PH
yes. i'm moving away from barracuda's to iron wolf pro's as when i get failures
