SMART Results help
flyinfitz1
replaced my old WD Red 4x3TB RaidZ2 array with Seagate Ironwold 4x6TB RaidZ2. Overall Ive been happy with the drives other than they run a little hotter. Can someone take a look at the SMART results? Im concerned about the seek error rate. Seems like all the drives have this high count. Im on FreeNAS-11.3-U3.2 with hardware specs in my signature. Thanks in advance for the help!
  1 Raw_Read_Error_Rate     0x000f   066   064   044    Pre-fail  Always       -       4373960
  3 Spin_Up_Time            0x0003   092   089   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       20
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   086   060   045    Pre-fail  Always       -       426268715
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       1670
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       20
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   062   056   040    Old_age   Always       -       38 (Min/Max 35/43)
191 G-Sense_Error_Rate      0x0032   098   098   000    Old_age   Always       -       4401
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       60
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       441
194 Temperature_Celsius     0x0022   038   044   000    Old_age   Always       -       38 (0 24 0 0 0)
195 Hardware_ECC_Recovered  0x001a   037   001   000    Old_age   Always       -       4373960
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       1643 (109 47 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       11427558799
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       27607682594
[\code]
Samuel Tai
flyinfitz1
You can also use a smartctl switch to convert the values: smartctl -a -v 1,raw48:54 /dev/daX
See this site for the explanation of how that -v works to change the attribute 1 as shown... you could also do it for other attributes like 7 and 195, I suppose.
flyinfitz1
Super helpful thanks!
flyinfitz1
is this a permanent fix?
It's not a "fix" as such, it just allows you to see the human-readable version of that value (which will always be stored in that difficult to read way by the on-disk SMART controller when it performs the tests) when you query the value... means you need to use the -v switch every time if you want to read the output properly.
