I'm trying to setup a FreeNAS server with a 9650SE-24M8 controller. Currently the controller is setup with JBOD for all drives. FreeNAS is setup with 3 drives temporarily using a RAIDZ while I experiment. However i'm having trouble getting SMART to work. Currently if I go to Storage -> Volumes -> View Disks I can see the disks. I do not get serial numbers in the GUI, not sure if this is expected or an indication of the problem. I did verify the box is checked for "Enable SMART". I've been trying to do SMART commands from the prompt to verify the hard drive supports SMART.
So I did smartctl -a -d 3ware,0 /dev/twa0
So now that I've proved the hard drive is supported it's time to give SMART a try! I click to start the service and I get the error:
Then the service turns back to off in the GUI.
So I checked out /usr/local/etc/smartd.conf and sure enough there's no entries.
I then tried adding -d 3ware,0 /dev/twa0 to Storage -> Volumes -> View Disks -> edit da0. Still the same error.
Then I tried adding a SMART Test to run by going to System -> SMART Tests -> Add test and created a conveyance test. I selected the 1 disk I'm experimenting with and the service still gives the same error on startup.
I've spent the last 3 hours with google and forum searches and I see alot of people have problems like mine but no definitive answer on how to fix it. A few people said they created startup scripts and whatnot but I couldn't find an entry that provided enough information that I could reproduce the result.
I tried creating entries manually, but FreeNAS seems to regenerate the smartd.conf file erasing my changes before the service starts. This was expected because of my searching but I figured I had nothing to lose.
Any ideas how I can troubleshoot this problem or how to resolve it? I'm half expecting someone is going to paste a link to some thread on how to fix it in 2 easy steps. There's alot of threads dealing with SMART issues but I'm pretty sure I've read them all at least once between all the different search terms I've used.
smartctl 5.42 2011-10-20 r3458 [FreeBSD 8.2-RELEASE-p9 amd64] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
Model Family: Western Digital Caviar Green
Device Model: WDC WD15EADS-00S2B0
Serial Number: WD-WCAVY0394928
LU WWN Device Id: 5 0014ee 258494bd0
Firmware Version: 01.00A01
User Capacity: 1,500,301,910,016 bytes [1.50 TB]
Sector Size: 512 bytes logical/physical
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Tue Aug 21 00:17:10 2012 CDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: (31560) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303f) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 1
3 Spin_Up_Time 0x0027 152 149 021 Pre-fail Always - 9400
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 24
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 35
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 23
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 14
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 115
194 Temperature_Celsius 0x0022 104 104 000 Old_age Always - 48
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Configuration file /usr/local/etc/smartd.conf parsed but has no entries (like /dev/hda)
