So I bought some SAS HDDs from eBay for dirt cheap, and first thing I did was to look at its SMART reading. Here is an example:
Very different from SATA drive's reading. Manufactured years ago but with few hours, looks like new old stock. Got a few ECC corrected errors, but no unrecoverable ones (I believe consumer drives only report the latter?). All looks good to me.
What is bugging me is that the model# H7240B520SUN4.0T is different from the physical lable, which is HUS726040AL5210. Maybe this was made by HGST for SUN, but SUN was bought well before the drive was made. Also it feels wired to have different #s on the label and burned in.
What's your thoughts on these drives?
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: HGST Product: H7240B520SUN4.0T Revision: M548 Compliance: SPC-4 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Logical block size: 512 bytes Physical block size: 4096 bytes Formatted with type 1 protection LU is fully provisioned Rotation Rate: 7200 rpm Form Factor: 3.5 inches Logical Unit id: 0x5000cca24400c050 Serial number: 001447M0DU1J N8G0DU1J Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Mon Sep 10 21:28:09 2018 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 34 C Drive Trip Temperature: 85 C Manufactured in week 47 of year 2014 Specified cycle count over device lifetime: 50000 Accumulated start-stop cycles: 6 Specified load-unload count over device lifetime: 600000 Accumulated load-unload cycles: 8 Elements in grown defect list: 0 Vendor (Seagate) cache information Blocks sent to initiator = 37877920563200 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 0 4 0 4 1705 1351.695 0 write: 0 13 0 13 4652 4508.933 0 verify: 0 0 0 0 2644 0.000 0 Non-medium error count: 0 SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background long Completed - 54 - [- - -] # 2 Background short Completed - 45 - [- - -] # 3 Background short Completed - 43 - [- - -] Long (extended) Self Test duration: 34237 seconds [570.6 minutes]
