Crustacean
- Jan 31, 2014
I'm not sure if there is a guide on understanding the output of a smart test, but after reading a few threads I still don't know what I'm looking at.
I'm getting the following email:
I've received it twice now in the span of 15 days. The number actually went down to 65520 in the last email. Is that number the count of bad sectors? That's quite a few.
Here's the output of smartctl -a /dev/ada6
I already have a replacement on the way, but does this drive need to be replaced? Is it dying?
Device: /dev/ada6, 65528 Offline uncorrectable sectors
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p4 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST1000DM003-9YN162
Serial Number: S1D261TQ
LU WWN Device Id: 5 000c50 04b630d4b
Firmware Version: CC4B
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Jun 19 12:38:39 2014 EDT
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/223651en
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 575) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 112) minutes.
Conveyance self-test routine
SCT capabilities: (0x3085) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 114 068 006 Pre-fail Always - 82908488
3 Spin_Up_Time 0x0003 097 097 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 145
5 Reallocated_Sector_Ct 0x0033 085 051 036 Pre-fail Always - 20032
7 Seek_Error_Rate 0x000f 088 060 030 Pre-fail Always - 5032305264
9 Power_On_Hours 0x0032 087 087 000 Old_age Always - 11819
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 144
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 3588
188 Command_Timeout 0x0032 100 095 000 Old_age Always - 1 1 10
189 High_Fly_Writes 0x003a 085 085 000 Old_age Always - 15
190 Airflow_Temperature_Cel 0x0022 071 050 045 Old_age Always - 29 (Min/Max 25/35)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 128
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 219
194 Temperature_Celsius 0x0022 029 050 000 Old_age Always - 29 (0 17 0 0 0)
197 Current_Pending_Sector 0x0012 100 001 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 001 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 11562h+55m+33.664s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 160718803930890
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 186223854901614
SMART Error Log Version: 1
ATA Error Count: 3226 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 3226 occurred at disk power-on lifetime: 11377 hours (474 days + 1 hours)
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 00 ff ff ff 4f 00 16d+14:57:37.362 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 16d+14:57:36.412 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 16d+14:57:35.294 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 16d+14:57:34.686 READ FPDMA QUEUED
Error 3225 occurred at disk power-on lifetime: 9373 hours (390 days + 13 hours)
60 00 00 ff ff ff 4f 00 19d+18:11:15.788 READ FPDMA QUEUED
60 00 80 ff ff ff 4f 00 19d+18:11:15.788 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 19d+18:11:15.700 READ LOG EXT
60 00 00 ff ff ff 4f 00 19d+18:11:12.248 READ FPDMA QUEUED
60 00 80 ff ff ff 4f 00 19d+18:11:12.247 READ FPDMA QUEUED
Error 3224 occurred at disk power-on lifetime: 9373 hours (390 days + 13 hours)
2f 00 01 10 00 00 00 00 19d+18:11:12.216 READ LOG EXT
60 00 00 ff ff ff 4f 00 19d+18:11:09.036 READ FPDMA QUEUED
60 00 80 ff ff ff 4f 00 19d+18:11:09.036 READ FPDMA QUEUED
Error 3223 occurred at disk power-on lifetime: 9373 hours (390 days + 13 hours)
2f 00 01 10 00 00 00 00 19d+18:11:09.033 READ LOG EXT
60 00 00 ff ff ff 4f 00 19d+18:11:05.829 READ FPDMA QUEUED
60 00 80 ff ff ff 4f 00 19d+18:11:05.828 READ FPDMA QUEUED
Error 3222 occurred at disk power-on lifetime: 9373 hours (390 days + 13 hours)
2f 00 01 10 00 00 00 00 19d+18:11:05.702 READ LOG EXT
60 00 00 ff ff ff 4f 00 19d+18:10:58.813 READ FPDMA QUEUED
60 00 80 ff ff ff 4f 00 19d+18:10:58.670 READ FPDMA QUEUED
# 1 Short offline Completed without error 00% 11801 -
# 2 Short offline Completed without error 00% 11777 -
# 3 Short offline Completed without error 00% 11753 -
# 4 Short offline Completed without error 00% 11729 -
# 5 Short offline Completed without error 00% 11705 -
# 6 Short offline Completed without error 00% 11681 -
# 7 Short offline Completed without error 00% 11657 -
# 8 Short offline Completed without error 00% 11633 -
# 9 Short offline Completed without error 00% 11609 -
#10 Short offline Completed without error 00% 11585 -
#11 Short offline Completed without error 00% 11561 -
#12 Short offline Completed without error 00% 11537 -
#13 Short offline Completed: read failure 90% 11513 1712505728
#14 Extended offline Completed: read failure 10% 11507 1850342456
#15 Short offline Completed without error 00% 11489 -
#16 Short offline Completed without error 00% 11465 -
#17 Short offline Completed without error 00% 11441 -
#18 Short offline Completed without error 00% 11417 -
#19 Short offline Completed without error 00% 10954 -
#20 Short offline Completed without error 00% 10931 -
#21 Short offline Completed without error 00% 10930 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
