SOLVED SMART errors, can i recover my data?
NoTalent
I am getting network errors when transferring data to my freenas system. googling around I see this thread:
https://forums.freenas.org/index.php?threads/extensive-scrub-duration.20548/
It looks like I'm in a very similar situation, I didn't have SMART tests running--I had it enabled and I thought that was enough.
I don't know how to decipher the smart data, but it looks like all my drives are failing? Can someone confirm? Possibly the only reason I might be able to get my data is due to the ECC memory?
Hardware/SW:
Build
FreeNAS-9.3-STABLE-201506042008
Platform AMD Opteron(tm) Processor 6128
Memory 32740MB (ECC)
zpool status
[root@freenas] /dev# zpool status
pool: Storage
state: ONLINE
status: The pool is formatted using a legacy on-disk format. The pool can
still be used, but some features are unavailable.
action: Upgrade the pool using 'zpool upgrade'. Once this is done, the
pool will no longer be accessible on software that does not support feature
flags.
scan: scrub repaired 0 in 30h12m with 0 errors on Mon Jul 6 06:12:57 2015
NAME STATE READ WRITE CKSUM
Storage ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/373da778-d5b9-11e2-a4c4-00e081c59efe ONLINE 0 0 0
gptid/ea86ce69-570a-11e2-bbc6-00e081c59efe ONLINE 0 0 0
gptid/eaedef68-570a-11e2-bbc6-00e081c59efe ONLINE 0 0 0
gptid/eb8a8c4e-570a-11e2-bbc6-00e081c59efe ONLINE 0 0 0
gptid/ebfdc64e-570a-11e2-bbc6-00e081c59efe ONLINE 0 0 0
gptid/ecba1095-570a-11e2-bbc6-00e081c59efe ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: none requested
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
NoTalent
Here are the SMART logs:
SMART info from each drive.
[root@freenas] /dev# smartctl -a /dev/ada0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
Model Family:     Western Digital RE3 Serial ATA
Device Model:     WDC WD1002FBYS-18W8B0
Serial Number:    xx
LU WWN Device Id: 5 0014ee 057077112
Add. Product Id:  DELL(tm)
Firmware Version: 03.00C09
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 2.5, 3.0 Gb/s
Local Time is:    Tue Jul  7 22:34:19 2015 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
                                        been run.
data collection:                (18000) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 208) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x303f) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   253   253   021    Pre-fail  Always       -       1975
  4 Start_Stop_Count        0x0032   098   098   000    Old_age   Always       -       2447
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   075   075   000    Old_age   Always       -       18817
10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1887
192 Power-Off_Retract_Count 0x0032   198   198   000    Old_age   Always       -       1866
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       580
194 Temperature_Celsius     0x0022   109   065   000    Old_age   Always       -       41
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Conveyance offline  Completed without error       00%      2459         -
[root@freenas] /dev# smartctl -a /dev/ada1
Model Family:     Seagate Barracuda 7200.12
Device Model:     ST31000524AS
Serial Number:    xx
LU WWN Device Id: 5 000c50 02a2a288e
Firmware Version: JC4B
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Tue Jul  7 22:34:22 2015 PDT
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  617) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        (   1) minutes.
recommended polling time:        ( 178) minutes.
SCT capabilities:              (0x103f) SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   107   099   006    Pre-fail  Always       -       14098517
  3 Spin_Up_Time            0x0003   100   100   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   075   075   020    Old_age   Always       -       25713
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   080   060   030    Pre-fail  Always       -       107644271
  9 Power_On_Hours          0x0032   078   078   000    Old_age   Always       -       19374
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       60
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       25770196998
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   063   057   045    Old_age   Always       -       37 (Min/Max 35/41)
194 Temperature_Celsius     0x0022   037   043   000    Old_age   Always       -       37 (0 20 0 0 0)
195 Hardware_ECC_Recovered  0x001a   024   013   000    Old_age   Always       -       14098517
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       19823 (67 148 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       1976616268
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       1481805202
No Errors Logged
# 1  Short offline       Completed without error       00%     19373         -
[root@freenas] /dev# smartctl -a /dev/ada2
Device Model:     ST31000528AS
Serial Number:    xx
LU WWN Device Id: 5 000c50 02ce5f258
Firmware Version: CC38
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Tue Jul  7 22:34:23 2015 PDT
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/213891en
                                        been run.
data collection:                (  600) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 174) minutes.
  1 Raw_Read_Error_Rate     0x000f   110   099   006    Pre-fail  Always       -       25487137
  3 Spin_Up_Time            0x0003   095   095   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   075   075   020    Old_age   Always       -       25799
  7 Seek_Error_Rate         0x000f   080   060   030    Pre-fail  Always       -       112808171
  9 Power_On_Hours          0x0032   078   078   000    Old_age   Always       -       19636
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       71
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   062   054   045    Old_age   Always       -       38 (Min/Max 36/42)
194 Temperature_Celsius     0x0022   038   046   000    Old_age   Always       -       38 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   031   017   000    Old_age   Always       -       25487137
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       19890 (65 113 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       221835777
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       2346872939
No Errors Logged
# 1  Short offline       Completed without error       00%     19636         -
NoTalent
Rest of the logs:
[root@freenas] /dev# smartctl -a /dev/ada3
Model Family:     Seagate Barracuda 7200.11
Device Model:     ST31000340AS
Serial Number:    xx
LU WWN Device Id: 5 000c50 0028a7cd9
Firmware Version: SD04
ATA Version is:   ATA/ATAPI-7 (minor revision not indicated)
Local Time is:    Tue Jul  7 22:34:24 2015 PDT
==> WARNING: There are known problems with these drives,
http://knowledge.seagate.com/articles/en_US/FAQ/207951en
http://knowledge.seagate.com/articles/en_US/FAQ/207957en
                                        been run.
data collection:                (  642) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 215) minutes.
SCT capabilities:              (0x003b) SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   109   099   006    Pre-fail  Always       -       22549946
  3 Spin_Up_Time            0x0003   091   086   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       909
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       1
  7 Seek_Error_Rate         0x000f   062   058   030    Pre-fail  Always       -       962485669647
  9 Power_On_Hours          0x0032   068   068   000    Old_age   Always       -       28763
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       5
12 Power_Cycle_Count       0x0032   100   037   020    Old_age   Always       -       119
190 Airflow_Temperature_Cel 0x0022   057   049   045    Old_age   Always       -       43 (Min/Max 42/48)
194 Temperature_Celsius     0x0022   043   051   000    Old_age   Always       -       43 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   049   020   000    Old_age   Always       -       22549946
No Errors Logged
# 1  Short offline       Completed without error       00%     28762         -
[root@freenas] /dev# smartctl -a /dev/ada4
Serial Number:    xx
LU WWN Device Id: 5 000c50 036569bb0
Firmware Version: CC3E
Local Time is:    Tue Jul  7 22:34:25 2015 PDT
                                        been run.
data collection:                (  609) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 179) minutes.
  1 Raw_Read_Error_Rate     0x000f   111   099   006    Pre-fail  Always       -       32056381
  4 Start_Stop_Count        0x0032   075   075   020    Old_age   Always       -       25988
  7 Seek_Error_Rate         0x000f   081   060   030    Pre-fail  Always       -       132297193
  9 Power_On_Hours          0x0032   070   070   000    Old_age   Always       -       26343
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       170
189 High_Fly_Writes         0x003a   001   001   000    Old_age   Always       -       10586
190 Airflow_Temperature_Cel 0x0022   059   052   045    Old_age   Always       -       41 (Min/Max 39/46)
194 Temperature_Celsius     0x0022   041   048   000    Old_age   Always       -       41 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   031   016   000    Old_age   Always       -       32056381
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       26798 (56 39 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       1571559041
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       215274516
No Errors Logged
# 1  Short offline       Completed without error       00%     26343         -
# 2  Short offline       Completed without error       00%      1712         -
[root@freenas] /dev# smartctl -a /dev/ada5
Serial Number:    xx
LU WWN Device Id: 5 000c50 0028ab3af
Local Time is:    Tue Jul  7 22:34:26 2015 PDT
                                        been run.
data collection:                (  634) seconds.
                                        command.
                                        power-saving mode.
  1 Raw_Read_Error_Rate     0x000f   109   099   006    Pre-fail  Always       -       22110523
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       418
  7 Seek_Error_Rate         0x000f   076   060   030    Pre-fail  Always       -       17373981721
  9 Power_On_Hours          0x0032   067   067   000    Old_age   Always       -       28940
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       7
12 Power_Cycle_Count       0x0032   100   037   020    Old_age   Always       -       115
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       1
190 Airflow_Temperature_Cel 0x0022   054   047   045    Old_age   Always       -       46 (Min/Max 44/51)
194 Temperature_Celsius     0x0022   046   053   000    Old_age   Always       -       46 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   050   021   000    Old_age   Always       -       22110523
No Errors Logged
# 1  Short offline       Completed without error       00%     28940         -
As @hugovsky said, all your drives are running on the warm side, and some are over 40 C, which we don't like to see. Try to improve airflow or move the server to a cooler environment.
I'm curious as to what makes you think that all your drives are failing. None of them are showing any current errors or problem sectors, and only one of them is showing any such history (and that's only one reallocated sector). In short, nothing about the SMART data except for the drive temps and the fact that you aren't running regular SMART tests is cause for concern.
Bidule0hm
Server Electronics Sorcerer
I agree with what has already been said.
Just to be sure you should run a long SMART test manually before re-doing the smartctl -a ;)
  • 194 Temperature_Celsius 0x0022 109 065 000 Old_age Always - 41
HOLY $/#&!
That drive has seen 85 degrees Celsius! See that 65? The encoding is 150 degrees - 65 degrees = 85 degrees.
NoTalent
danb35, thank you for this information and your reply. I do not know how to decipher the SMART log results. Before I ask anymore stupid questions, is there a manual for this or previous posts where this is described?
I saw the really large numbers in the right-most column and thought that was the number of errors my drives were seeing.
NoTalent
HOLY $/#&!
Ericloewe, how long does the SMART data stay with the drive? I did not get this drive new, so possibly it saw a high temp from the previous owner? The system is not in a data center, but sits next to a desk near my other computer where the ambient temperature is ~30C. I will use a IR temperature gun to get an idea of the disk case temperature.
HOLY $/#&!
That probably means this one isn't too good, then:
190 Airflow_Temperature_Cel 0x0022   068   046   045    Old_age   Always       -       32 (Min/Max 28/38)
194 Temperature_Celsius     0x0022   032   054   000    Old_age   Always       -       32 (0 9 0 0 0)
I don't think there is a cohesive guide on SMART around here, but I might be wrong.
NoTalent
You should cool down that drives. They're running too hot. Try to keep them between 30-40º. To me, it seems that only ada3 should be closely monitored. It already has 1 recovered sector. Schedule everyday short tests and every 1-2weeks long tests to all drives. Other drives seem fine. What version of freenas are you using?
I did a quick check with my IR gun, the drives are ~40C which is too warm. I'm going to blow out the case and ensure the fans all working properly.
NoTalent
Updating thread--as many helpful users of this forum pointed out, I do not have S.M.A.R.T errors on my drives. I was not interpreting the logs correctly. I will open a new thread on the network error I am seeing.
Thanks everyone for the help.
Do have spares handy. Those drives have literally been cooked to the edge of their (wildly optimistic) temperature range.
NoTalent
I'm trying to figure out my "Network Error 0x8007003B" issue. If I can't I might just buy 3-4 4TB drives and start over, then copy my data to that drive. I think I have <4TB of data on the volume so I could move it and expand.
