Kamal Soor
- Jul 22, 2014
Help!
I just added a 2nd IBM 1015 (IT mode) to my system. I got errors when I created a New Volume, I thought I gotten a bad drive, OR I'd had overloaded my 500 watt power supply (13 drives and I was adding 3 new) so I deleted the volume and tried to figure out what was going on by adding the drives one at a time as single drive Volumes.
Last night I unplugged the New drives and found that I was getting a SMART Error this morning. I can't see any errors, can someone help? Is my drive at da5 failing?
Thanks,
Kamal
SMART Error!:
my system.
FreeNAS-9.10.2-U4 (27ae72978)
motherboard: ASUS 787-A
cpu: Core(TM) i5-4670K CPU @ 3.40GHz
Memory: 16226MBS
Load Average: 0.22, 0.20, 0.17
2 IBM 1015 (IT Mode)
Intel ethernet card.
13 drives
my zpools look ok
here is the out put from the SMARTCTL and I don't see any errors here either.
Thanks,
Kamal
SMART Error!:
- CRITICAL: Oct. 12, 2017, 7:29 a.m. - Device: /dev/da5 [SAT], FAILED SMART self-check. BACK UP DATA NOW!
- CRITICAL: Oct. 12, 2017, 7:29 a.m. - Device: /dev/da5 [SAT], Failed SMART usage Attribute: 7 Seek_Error_Rate.
my system.
Memory: 16226MBS
13 drives
my zpools look ok
[root@freenas] ~# zpool status pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h8m with 0 errors on Tue Oct 3 03:53:25 2017 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 gptid/ed1791d2-c2d7-11e4-87ea-e03f49ea0e7e ONLINE 0 0 0 errors: No known data errors pool: vault1 state: ONLINE scan: scrub repaired 0 in 8h42m with 0 errors on Mon Sep 4 14:43:02 2017 config: NAME STATE READ WRITE CKSUM vault1 ONLINE 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/1e116bda-e94b-11e3-b7da-e03f49ea0e7e ONLINE 0 0 0 gptid/1e6aac9e-e94b-11e3-b7da-e03f49ea0e7e ONLINE 0 0 0 gptid/1ec504be-e94b-11e3-b7da-e03f49ea0e7e ONLINE 0 0 0 errors: No known data errors pool: vault2 state: ONLINE scan: scrub repaired 0 in 9h55m with 0 errors on Tue Sep 5 15:55:59 2017 config: NAME STATE READ WRITE CKSUM vault2 ONLINE 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/863543f1-eeb0-11e3-86d5-e03f49ea0e7e ONLINE 0 0 0 gptid/868a7e4d-eeb0-11e3-86d5-e03f49ea0e7e ONLINE 0 0 0 gptid/7cf2e64a-fdb2-11e4-aa9c-e03f49ea0e7e ONLINE 0 0 0 errors: No known data errors pool: vault3 state: ONLINE scan: scrub repaired 0 in 11h18m with 0 errors on Wed Sep 13 17:18:52 2017 config: NAME STATE READ WRITE CKSUM vault3 ONLINE 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/9ff29509-6473-11e4-bc08-e03f49ea0e7e ONLINE 0 0 0 gptid/a1f384be-6473-11e4-bc08-e03f49ea0e7e ONLINE 0 0 0 gptid/a3d72edb-6473-11e4-bc08-e03f49ea0e7e ONLINE 0 0 0 errors: No known data errors pool: vault4 state: ONLINE scan: scrub in progress since Thu Oct 12 06:00:00 2017 4.35T scanned out of 10.2T at 259M/s, 6h37m to go 0 repaired, 42.44% done config: NAME STATE READ WRITE CKSUM vault4 ONLINE 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/e01879f6-71de-11e5-90fe-e03f49ea0e7e ONLINE 0 0 0 gptid/e29ba397-71de-11e5-90fe-e03f49ea0e7e ONLINE 0 0 0 gptid/e540944c-71de-11e5-90fe-e03f49ea0e7e ONLINE 0 0 0 errors: No known data errors pool: vault5 state: ONLINE scan: scrub repaired 0 in 2h40m with 0 errors on Sun Sep 17 07:40:01 2017 config: NAME STATE READ WRITE CKSUM vault5 ONLINE 0 0 0 gptid/e5225018-6332-11e7-bdb8-e03f49ea0e7e ONLINE 0 0 0 errors: No known data errors [root@freenas] ~#
[root@freenas] ~# smartctl -a /dev/da5 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: HGST Deskstar NAS Device Model: HGST HDN724040ALE640 Serial Number: PK2334PCJSDPKB LU WWN Device Id: 5 000cca 24ce6d333 Firmware Version: MJAOA5E0 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Oct 12 10:54:44 2017 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 24) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 569) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 123 123 054 Pre-fail Offline - 125 3 Spin_Up_Time 0x0007 253 253 024 Pre-fail Always - 112 (Average 121) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 1062 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 119 119 020 Pre-fail Offline - 35 9 Power_On_Hours 0x0012 098 098 000 Old_age Always - 15695 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 143 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1071 193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 1071 194 Temperature_Celsius 0x0002 193 193 000 Old_age Always - 31 (Min/Max 19/38) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 15561 - # 2 Extended offline Completed without error 00% 15441 - # 3 Extended offline Completed without error 00% 15258 - # 4 Extended offline Completed without error 00% 15138 - # 5 Short offline Completed without error 00% 15101 - # 6 Short offline Completed without error 00% 15100 - # 7 Short offline Completed without error 00% 15077 - # 8 Short offline Completed without error 00% 15076 - # 9 Extended offline Completed without error 00% 15018 - #10 Extended offline Completed without error 00% 14767 - #11 Extended offline Completed without error 00% 14637 - #12 Extended offline Completed without error 00% 14517 - #13 Extended offline Completed without error 00% 14398 - #14 Short offline Completed without error 00% 14361 - #15 Short offline Completed without error 00% 14360 - #16 Short offline Completed without error 00% 14337 - #17 Short offline Completed without error 00% 14336 - #18 Extended offline Completed without error 00% 14278 - #19 Extended offline Completed without error 00% 14159 - #20 Extended offline Completed without error 00% 14039 - #21 Extended offline Completed without error 00% 14015 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. [root@freenas] ~#
