Newbie here. please help.
Alert CRITICAL: Device: /dev/ada3, 1 Currently unreadable (pending) sectors
OS: Current Train: FreeNAS-9.3-STABLE (Installed OS)
Zpool status seems okay, here it is:
smartctl -a /dev/ada3
]0;root@freenas:~[[1mroot@freenas[m] [1m~[m# zpp[Kool status
  pool: OrgVol
state: ONLINE
  scan: scrub repaired 0 in 6h35m with 0 errors on Fri May 15 08:35:34 2015
    OrgVol                                          ONLINE       0     0     0
      raidz1-0                                      ONLINE       0     0     0
        gptid/2ceb1ef3-85ad-11e4-a805-4439c494b325  ONLINE       0     0     0
        gptid/2daf6dc8-85ad-11e4-a805-4439c494b325  ONLINE       0     0     0
        gptid/2e70ff38-85ad-11e4-a805-4439c494b325  ONLINE       0     0     0
        gptid/2f2d8157-85ad-11e4-a805-4439c494b325  ONLINE       0     0     0
        gptid/2ff38ed2-85ad-11e4-a805-4439c494b325  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
state: ONLINE
  scan: none requested
    freenas-boot  ONLINE       0     0     0
      da0p2     ONLINE       0     0     0
errors: No known data errorssmartctl -a /dev/ada3
]0;root@freenas:~[[1mroot@freenas[m] [1m~[m# smartc[K[K[K[K[K[Ksmartcl[Ktl -a /dev/ada3
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WCC4NHZDPCJ4
LU WWN Device Id: 5 0014ee 2602a56fd
Firmware Version: 82.00A82
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri May 15 14:23:54 2015 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
Self-test execution status:      ( 241)    Self-test routine in progress...
                    10% of test remaining.
data collection:         (39900) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 400) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x703d)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       25
  3 Spin_Up_Time            0x0027   190   179   021    Pre-fail  Always       -       5466
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       72
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       3651
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       72
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       60
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       54
194 Temperature_Celsius     0x0022   116   111   000    Old_age   Always       -       34
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       1
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   199   000    Old_age   Offline      -       15
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%      3471         -
# 2  Short offline       Completed: read failure       70%      3339         1564476880
# 3  Short offline       Completed without error       00%      3339         -
# 4  Short offline       Completed without error       00%      3338         -
# 5  Short offline       Completed without error       00%      3337         -
# 6  Short offline       Completed without error       00%      3336         -
# 7  Short offline       Completed without error       00%      3335         -
# 8  Short offline       Completed without error       00%      3334         -
# 9  Short offline       Completed without error       00%      3333         -
#10  Short offline       Completed without error       00%      3332         -
#11  Short offline       Completed without error       00%      3331         -
#12  Short offline       Completed without error       00%      3330         -
#13  Short offline       Completed without error       00%      3329         -
#14  Short offline       Completed: read failure       70%      3327         1564476536
#15  Short offline       Completed: read failure       50%      3327         1564552088
#16  Short offline       Completed without error       00%      3326         -
#17  Short offline       Completed: read failure       40%      3325         1564642664
#18  Short offline       Completed: read failure       60%      3323         1564478912
#19  Short offline       Completed without error       00%      3323         -
#20  Short offline       Completed without error       00%      3322         -
#21  Short offline       Completed without error       00%      3321         -
