Slow write speed
Anon_the_Nine
Hey i'm very new to Freenas i built my systems only few days ago. I have been transferring data from my PC to my NAS and only get about 40MBps writes. I was hoping if someone can help me find out what is wrong with my config as i'm fairly certain i should be seeing higher write speeds. I have run the ipconfig command and the "1000baseT <full-duplex>" has been detected. Could it be an issue with my cables?
I am also suspect that the read speeds are also having the same issue however i can't fully identify for certain as i don't know how to test the read speeds.
Thanks in advanced
CPU: Intel Xeon E3-1230v6
Motherboard: Supermicro X11SSL-F
RAM: 16GB Crucial memory
4 x 4tb Seagate iron wolf in raidz2
1 x Crucial MX500 boot drive
Anon_the_Nine
i also did a iperf test which falls in line to the speeds i'm getting
root@freenas[~]# iperf -s 192.168.1.10
iperf: ignoring extra argument -- 192.168.1.10
Server listening on TCP port 5001
TCP window size: 64.0 KByte (default)
[  4] local 192.168.1.3 port 5001 connected with 192.168.1.12 port 52550
[ ID] Interval       Transfer     Bandwidth
[  4]  0.0-10.0 sec   362 MBytes   303 Mbits/sec
Anon_the_Nine
Seriously? so if i was plugged straight in i would get close to the 1Gb speed? If so its not really possible for me to keep my machine wired as the router is in another room and as much as i would like to i am unable to directly attach a cable from there so should i run power line or is it not worth?
SweetAndLow
Sweet'NASty
300mbps over wireless is excellent, you can't really do much better.
