Slow write performance
ulf
Have build a FreeNAS server running 8.3.1-p2
Based on an AMD E-450 with 16 GB RAM.
4 x 3 TB disks WD RED running ZFS
The volume is now 67% used (3.5TiB) with 1.7TiB Free.
Connected to a Core-i7/940 machine over a D-Link DIR_685 storage router.
I used it mainly to store MP4 copies of movies recorded on DVD+R.
Typically, it used to take about 15 minutes to convert a DVD directly to the NAS,
and now it suddenly takes almost an hour.
Tried to figure out why, so I first copied the DVD to a hard drive.
This did not change conversion time, but when I changed output
directory from the NAS to a disk, it was back at normal speed.
If I copy a large file to the NAS (1 GB), then it copies at 4-5 MB / second,
which seems quite slow.
I read somewhere, that the size of the DRAM is critical when running ZFS.
Have I reached a limit on DRAM and need more than 16 GB
(Thats the MAX supported by the motherboard)?
Any other reason for the real slow write speed?
That sounds like you may have a failing disk.
Post the output of the command smartctl -a -q noserial /dev/(yourdiskhere)
Remember to post it for all of your disks. :)
ulf
OK, here are the selftest in an attached file.
Tried again, and I now get 11-12 MB/s but conversion time still ~45 minutes.
I rebooted right before I tested a file copy, and maybe the system was busy scanning for files
during the first test.
The reason for reboot was the slow write performance though.
When I look at reports, I noticed that CPU was at 100% running mostly in system.
Now it has dropped to normal ratings, and write speed is OK again.
No clue why.
Physical memory seems to have around 0.5-1GB free
  • disktest-2013-08-25.txt
ulf
Looked at the history of the "CPU Usage" log.
Apparently, the system is doing something on Sundays once a month,
because the CPU usage goes up to 100% and stays there between 0:00 and 9:00.
gpsguy
Active Member
It might be scrubbing your pool. Do a:
zpool status -v
to see when it was last run
Sent from my phone
Your hard drive looks good. I bet it was a scrub come to think of it.
pbucher
Has you add more files the scrub will take longer, hence why you are just now noticing it.
