I first want to thank everyone on this forum for the wealth of knowledge I have gain while setting up my TrueNAS server!
I have had my TrueNAS Scale server set up for about 3 months now, and I had scrubs set to run once a month, but recently I noticed that they have never actually run. I did a manual scrub, and let it run overnight; the next morning, it showed an estimated completion time of two months. Also, since setting up the server, I have had mediocre performance when accessing SMB shares, and occasionally having movies buffer while using Plex. I just haven't had the time to sit down and focus on troubleshooting it until now.
Here is my current setup.
OS: TrueNAS-SCALE-22.12.1
Motherboard: Supermicro X11SSH-LN4F
CPU: Intel Xeon E3-1230 v6
RAM: 32GB (2 x 16GB) ECC RDIMM DDR4-2400
Vdev: 8 x 8TB Dell EMC HGST HDD in RaidZ2
HBA: LSI SAS2308-8i IT
Problem 1: Slow access
I stopped all my apps except NetData and then ran Jgreco’s solnet-array-test-v3. The drives were all performing close to each other at around 180 MBs. I then tried downloading a folder with about 2 TB of data via WinSCP, and I was only getting around 2-10 MBs. So something was wrong!
After a few days or researching and testing, what I found was that the issue was with drive compression. When I transfer files through SMB or WinSCP, I get transfer speeds of around 2-10 MB/s. When I disable compression (defaulted to LZ4), I get speeds of 113 MB/s (basically maxing out my 1Gbs connection)
The resolution for the slow network speeds was to turn off drive compression. However, I was unsure why drive compression would cause such a significant slowdown.
Problem 2: Extended scrub and drive test times
After fixing the network slowdown by disabling drive compression, I reran the scrub, which did not improve the speed. The estimated completion time was still somewhere around 2 months.
I ran a SMART Long test and found that 5 of my 8 drives finished the long test within 10 hours. 2 of the 8 drives (sdc and sdd) finished around 24 hours, and 1 of the 8 drives (sdc) finished around 30-36 hours. Although the run times were slower than in the past, there were no errors in the SMART tests.
During the parallel run test, 7 of the 8 drives were all very close to each other, but 1 drive (sda) took twice as long to finish.
Below is a summary of the drives and the tests that I have run so far. (SMART and Solnet Array Test). The items with the asterisk (*) are the ones that are slower than average. The parallel seek test is still running and probably has another 4+ hours left.
Could the issue be with the HBA, and not the drives?
My thoughts would be to take out the Nvidia card and move the HBA into that slot to test if it is the PCIe slot. Is that worth wild?
I do not have another HBA card, so testing the HBA card will probably require destroying my pool and plug 6 of the 8 drives into the MB’s 6 SATA plugs, create a new pool, and then test the performance.
I would like to hear y’alls advice on troubleshooting this problem!
Solnet Array Tests
Disk SMART Long Serial Parall % of Parall Run
Duration (h) MB/sec MB/sec Serial Time (sec)
sda 10 187 178 95 104,535*
sdb 10 189 188 100 53,761
sdc 36* 166* 176 106 54,436
sdd 24* 186 189 102 53,924
sde 10 190 192 101 52,987
sdf 24* 186 157 85* 55,030
sdg 10 188 182 96 53,763
sdh 10 188 185 99 53,879
