Slow ssh/network Performance on 11.2-Beta3
lulu
I've installed a fresh install of 11.2-BETA3 and I've ended up with freezing ssh I made a little video to show it.
Earlier I've had 11.1 on the same hardware and the same network and it operated normally.
Here is the video
wblock
Documentation Engineer
I do not have speakers on this desktop and could not tell what was going on in that video. Possibly it was pauses in SSH output, but it was difficult to tell. Please attempt to describe the problem in text.
lulu
When I’m inputting something to the ssh it freezes for 1-5 seconds and it is incredibly slow.
In the video, I was constantly inputting something and you can see that it froze for several seconds and then it inputted all at character at once.
It occurs via SSH and GUI shell.
It works normally when directly inputted to nas with keyboard connected to it.
wblock
What are the hardware specifications of the machine running FreeNAS? Specifically, how much RAM does it have?
lulu
@wblock It is build from a gaming pc
I7-3960x
16gb ddr 3 ram
I was running 11.1 on the same machine and it was operating super fast
lulu
this is from logging into ssh in debug3 mode
OpenSSH_7.8p1, LibreSSL 2.7.3
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 48: Applying options for *
debug2: resolve_canonicalize: hostname 192.168.1.24 is address
debug2: ssh_connect_direct
debug1: Connecting to 192.168.1.24 [192.168.1.24] port 22.
debug1: Connection established.
debug1: identity file /Users/lucjangrzesik/.ssh/id_rsa type -1
debug1: identity file /Users/lucjangrzesik/.ssh/id_rsa-cert type -1
debug1: identity file /Users/lucjangrzesik/.ssh/id_dsa type -1
debug1: identity file /Users/lucjangrzesik/.ssh/id_dsa-cert type -1
debug1: identity file /Users/lucjangrzesik/.ssh/id_ecdsa type -1
debug1: identity file /Users/lucjangrzesik/.ssh/id_ecdsa-cert type -1
debug1: identity file /Users/lucjangrzesik/.ssh/id_ed25519 type -1
debug1: identity file /Users/lucjangrzesik/.ssh/id_ed25519-cert type -1
debug1: identity file /Users/lucjangrzesik/.ssh/id_xmss type -1
debug1: identity file /Users/lucjangrzesik/.ssh/id_xmss-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.8
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.5-hpn14v5
debug1: match: OpenSSH_7.5-hpn14v5 pat OpenSSH_7.0*,OpenSSH_7.1*,OpenSSH_7.2*,OpenSSH_7.3*,OpenSSH_7.4*,OpenSSH_7.5*,OpenSSH_7.6*,OpenSSH_7.7* compat 0x04000002
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to 192.168.1.24:22 as 'lulu'
debug3: hostkeys_foreach: reading file "/Users/lucjangrzesik/.ssh/known_hosts"
debug3: record_hostkey: found key type ECDSA in file /Users/lucjangrzesik/.ssh/known_hosts:1
debug3: load_hostkeys: loaded 1 keys from 192.168.1.24
debug3: order_hostkeyalgs: prefer hostkeyalgs: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,ext-info-c
debug2: host key algorithms: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519-cert-v01@openssh.com,rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ssh-ed25519,rsa-sha2-512,rsa-sha2-256,ssh-rsa
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: host key algorithms: ssh-rsa,rsa-sha2-512,rsa-sha2-256,ecdsa-sha2-nistp256,ssh-ed25519
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,none
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,none
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug3: send packet: type 30
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug3: receive packet: type 31
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:D7dBr9EFsbaetw0buZL5LmPSglufp4Sa9+SdJrnclBk
debug1: Host '192.168.1.24' is known and matches the ECDSA host key.
debug1: Found key in /Users/lucjangrzesik/.ssh/known_hosts:1
debug3: send packet: type 21
debug2: set_newkeys: mode 1
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: receive packet: type 21
debug1: SSH2_MSG_NEWKEYS received
debug2: set_newkeys: mode 0
debug2: key: /Users/lucjangrzesik/.ssh/id_rsa (0x0)
debug2: key: /Users/lucjangrzesik/.ssh/id_dsa (0x0)
debug2: key: /Users/lucjangrzesik/.ssh/id_ecdsa (0x0)
debug2: key: /Users/lucjangrzesik/.ssh/id_ed25519 (0x0)
debug2: key: /Users/lucjangrzesik/.ssh/id_xmss (0x0)
debug3: send packet: type 5
debug3: receive packet: type 7
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521>
debug3: receive packet: type 6
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug3: send packet: type 50
debug3: receive packet: type 51
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /Users/lucjangrzesik/.ssh/id_rsa
debug3: no such identity: /Users/lucjangrzesik/.ssh/id_rsa: No such file or directory
debug1: Trying private key: /Users/lucjangrzesik/.ssh/id_dsa
debug3: no such identity: /Users/lucjangrzesik/.ssh/id_dsa: No such file or directory
debug1: Trying private key: /Users/lucjangrzesik/.ssh/id_ecdsa
debug3: no such identity: /Users/lucjangrzesik/.ssh/id_ecdsa: No such file or directory
debug1: Trying private key: /Users/lucjangrzesik/.ssh/id_ed25519
debug3: no such identity: /Users/lucjangrzesik/.ssh/id_ed25519: No such file or directory
debug1: Trying private key: /Users/lucjangrzesik/.ssh/id_xmss
debug3: no such identity: /Users/lucjangrzesik/.ssh/id_xmss: No such file or directory
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
lulu@192.168.1.24's password:
debug2: we sent a password packet, wait for reply
debug3: receive packet: type 52
debug1: Authentication succeeded (password).
Authenticated to 192.168.1.24 ([192.168.1.24]:22).
debug1: channel 0: new [client-session]
debug3: ssh_session2_open: channel_new: 0
debug2: channel 0: send open
debug3: send packet: type 90
debug1: Requesting no-more-sessions@openssh.com
debug3: send packet: type 80
debug1: Entering interactive session.
debug1: pledge: network
debug3: receive packet: type 80
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug3: receive packet: type 91
debug2: channel_input_open_confirmation: channel 0: callback start
debug2: fd 3 setting TCP_NODELAY
debug3: ssh_packet_set_tos: set IP_TOS 0x48
debug2: client_session2_setup: id 0
debug2: channel 0: request pty-req confirm 1
debug3: send packet: type 98
debug1: Sending environment.
debug3: Ignored env TERM_PROGRAM
debug3: Ignored env SHELL
debug3: Ignored env TMPDIR
debug3: Ignored env Apple_PubSub_Socket_Render
debug3: Ignored env TERM_PROGRAM_VERSION
debug3: Ignored env TERM_SESSION_ID
debug3: Ignored env USER
debug3: Ignored env SSH_AUTH_SOCK
debug3: Ignored env PATH
debug3: Ignored env PWD
debug3: Ignored env XPC_FLAGS
debug3: Ignored env XPC_SERVICE_NAME
debug3: Ignored env SHLVL
debug3: Ignored env HOME
debug3: Ignored env LOGNAME
debug1: Sending env LC_CTYPE = UTF-8
debug2: channel 0: request env confirm 0
debug3: Ignored env _
debug3: Ignored env __CF_USER_TEXT_ENCODING
debug2: channel 0: request shell confirm 1
debug2: channel_input_open_confirmation: channel 0: callback done
debug2: channel 0: open confirm rwindow 0 rmax 32768
debug3: receive packet: type 99
debug2: channel_input_status_confirm: type 99 id 0
debug2: PTY allocation request accepted on channel 0
debug2: channel 0: rcvd adjust 65536
debug2: shell request accepted on channel 0
Last login: Tue Oct 16 20:58:55 2018 from 192.168.1.21
lulu
netstats also
root@freenas[/]# netstat -s
tcp:
11442 packets sent
6391 data packets (1366605 bytes)
923 data packets (116809 bytes) retransmitted
48 data packets unnecessarily retransmitted
0 resends initiated by MTU discovery
3431 ack-only packets (1009 delayed)
0 URG only packets
0 window probe packets
0 window update packets
778 control packets
11179 packets received
5636 acks (for 1369153 bytes)
524 duplicate acks
0 acks for unsent data
5280 packets (1180244 bytes) received in-sequence
130 completely duplicate packets (38568 bytes)
0 old duplicate packets
4 packets with some dup. data (220 bytes duped)
138 out-of-order packets (13586 bytes)
0 packets (0 bytes) of data after window
0 window probes
396 window update packets
6 packets received after close
0 discarded for bad checksums
0 discarded for bad header offset fields
0 discarded because packet too short
0 discarded due to memory problems
369 connection requests
395 connection accepts
0 bad connection attempts
0 listen queue overflows
0 ignored RSTs in the windows
764 connections established (including accepts)
723 times used RTT from hostcache
723 times used RTT variance from hostcache
37 times used slow-start threshold from hostcache
771 connections closed (including 4 drops)
27 connections updated cached RTT on close
28 connections updated cached RTT variance on close
21 connections updated cached ssthresh on close
0 embryonic connections dropped
5636 segments updated rtt (of 5093 attempts)
789 retransmit timeouts
1 connection dropped by rexmit timeout
0 persist timeouts
0 connections dropped by persist timeout
0 Connections (fin_wait_2) dropped because of timeout
0 keepalive timeouts
0 keepalive probes sent
0 connections dropped by keepalive
1367 correct ACK header predictions
2468 correct data packet header predictions
396 syncache entries added
6 retransmitted
0 dupsyn
1 dropped
395 completed
0 bucket overflow
0 cache overflow
0 reset
1 stale
0 aborted
0 badack
0 unreach
0 zone failures
397 cookies sent
0 cookies received
3 hostcache entries added
0 bucket overflow
73 SACK recovery episodes
127 segment rexmits in SACK recovery episodes
7204 byte rexmits in SACK recovery episodes
603 SACK options (SACK blocks) received
113 SACK options (SACK blocks) sent
0 SACK scoreboard overflow
0 packets with ECN CE bit set
0 packets with ECN ECT(0) bit set
0 packets with ECN ECT(1) bit set
0 successful ECN handshakes
0 times ECN reduced the congestion window
0 packets with matching signature received
0 packets with bad signature received
0 times failed to make signature due to no SA
0 times unexpected signature received
0 times no signature provided by segment
TCP connection count by state:
0 connections in CLOSED state
6 connections in LISTEN state
0 connections in SYN_SENT state
0 connections in SYN_RCVD state
8 connections in ESTABLISHED state
0 connections in CLOSE_WAIT state
0 connections in FIN_WAIT_1 state
0 connections in CLOSING state
0 connections in LAST_ACK state
0 connections in FIN_WAIT_2 state
12 connections in TIME_WAIT state
udp:
3974 datagrams received
0 with incomplete header
0 with bad data length field
0 with bad checksum
0 with no checksum
234 dropped due to no socket
79 broadcast/multicast datagrams undelivered
0 dropped due to full socket buffers
0 not for hashed pcb
3661 delivered
3713 datagrams output
0 times multicast source filter matched
ip:
15170 total packets received
0 bad header checksums
0 with size smaller than minimum
0 with data size < data length
0 with ip length > max ip packet size
0 with header length < data size
0 with data length < header length
0 with bad options
0 with incorrect version number
0 fragments received
0 fragments dropped (dup or out of space)
0 fragments dropped after timeout
0 packets reassembled ok
15167 packets for this host
0 packets for unknown/unsupported protocol
0 packets forwarded (0 packets fast forwarded)
3 packets not forwardable
16 packets received for unknown multicast group
0 redirects sent
16355 packets sent from this host
0 packets sent with fabricated ip header
0 output packets dropped due to no bufs, etc.
4 output packets discarded due to no route
0 output datagrams fragmented
0 fragments created
0 datagrams that can't be fragmented
0 tunneling packets that can't find gif
0 datagrams with bad address in header
icmp:
230 calls to icmp_error
0 errors not generated in response to an icmp message
Output histogram:
destination unreachable: 230
0 messages with bad code fields
0 messages less than the minimum length
0 messages with bad checksum
0 messages with bad length
0 multicast echo requests ignored
0 multicast timestamp requests ignored
Input histogram:
destination unreachable: 4
0 message responses generated
0 invalid return addresses
0 no return routes
ICMP address mask responses are disabled
igmp:
14 messages received
0 messages received with too few bytes
0 messages received with wrong TTL
0 messages received with bad checksum
7 V1/V2 membership queries received
0 V3 membership queries received
0 membership queries received with invalid field(s)
7 general queries received
0 group queries received
0 group-source queries received
0 group-source queries dropped
7 membership reports received
0 membership reports received with invalid field(s)
7 membership reports received for groups to which we belong
0 V3 reports received without Router Alert
872 membership reports sent
carp:
0 packets received (IPv4)
0 packets received (IPv6)
0 packets discarded for wrong TTL
0 packets shorter than header
0 discarded packets with a bad version
0 discarded for bad authentication
0 discarded for bad vhid
0 discarded because of a bad address list
0 packets sent (IPv4)
0 packets sent (IPv6)
0 send failed due to mbuf memory error
arp:
1174 ARP requests sent
43 ARP replies sent
315 ARP requests received
251 ARP replies received
567 ARP packets received
1601 total packets dropped due to no ARP entry
0 ARP entrys timed out
0 Duplicate IPs seen
ip6:
8 total packets received
0 with bad options
0 fragments that exceeded limit
4 packets for this host
0 packets forwarded
0 packets not forwardable
0 redirects sent
8 packets sent from this host
16 output packets discarded due to no route
0 fragments created
0 packets that violated scope rules
0 multicast packets which we don't join
Input histogram:
UDP: 4
ICMP6: 4
Mbuf statistics:
4 one mbuf
two or more mbuf:
lo0= 4
0 one ext mbuf
0 two or more ext mbuf
0 packets whose headers are not contiguous
0 packets discarded because of too many headers
5 failures of source address selection
source addresses on a non-outgoing I/F
5 addresses scope=0xf
Source addresses selection rule applied:
5 same address
icmp6:
4 calls to icmp6_error
0 errors not generated in response to an icmp6 message
0 errors not generated because of rate limitation
Output histogram:
unreach: 4
0 messages < minimum length
0 bad checksums
Input histogram:
unreach: 4
Histogram of error messages to be generated:
0 no route
0 administratively prohibited
0 beyond scope
0 address unreachable
4 port unreachable
0 packet too big
0 time exceed transit
0 time exceed reassembly
0 erroneous header field
0 unrecognized next header
0 unrecognized option
0 redirect
0 unknown
0 messages with too many ND options
0 messages with bad ND options
0 bad neighbor solicitation messages
0 bad neighbor advertisement messages
0 bad router solicitation messages
0 bad router advertisement messages
0 bad redirect messages
0 path MTU changes
rip6:
0 messages received
0 checksum calculations on inbound
0 messages dropped due to no socket
0 multicast messages dropped due to no socket
0 messages dropped due to full socket buffers
0 delivered
0 datagrams output
lulu
Anyone?
I've tried reinstalling it several times the result is always the same ssh is freezing when typing for several seconds.
I've installed 11.1 and ssh right out the box is operating normally.
Please help me resolve this bug
