I've been using Plex without any problems remotely for a few years, but for the last couple of months I have experienced horrible upload speeds (from Plex -- in the form of buffering every few seconds) and I'm not sure why -- at least I suspect that's the problem. The utilization of everything on the server looks low, and nothing has changed, I also have 35mbps upload speeds (I can't easily test it atm as I don't have direct access to the network that the server is on, but I can run a speedtest through my extremely slow/shitty VPN and through that network and get 3-10 Mbps upload, so without the VPN in the way, I have no doubts it would be 20-30 Mbps).
Any ideas what could be causing the problem (/is there a dummy service I can upload to from command line if I SSH into the server)?
Specs in sig.
Specs in sig.
