So moved from Core to Scale (dragonfish). Simple upgrade (was impressed on how smooth that went)
Now, as for apps...Got my radarr/sonarr/etc. pipeline setup along with Plex.
However, I cannot get decent playback from Plex in this scenario. Everything from not enough CPU resources displayed on the client to if I'm lucky stuttering on 4k videos. I've messed with transcoder settings to no avail.
Another thing is PV mount points. When sabnzbd downloads and expands the archive I notice it will not instantly move the file (rename to another folder) and instead does another copy. Mount point options in the Plex portion aren't exactly straightforward...
Need to add specs...
cpu i5 10400
32gb
9208 sas card
3 separate mirrored vdevs making the pool
cpu i5 10400
32gb
9208 sas card
