Shutdown task not visible after update
Kiyoshi
I updated my system from freenas to truenas and now my shut down schedule is not visible in Init/Shutdown Scripts but is still actively shutting down my system.
Kris Moore
SVP of Engineering
Administrator
That is weird, can you check the output of "midclt call initshutdownscript.query" from the CLI?
Kiyoshi
Sorry for my dumb question am I supposed put "midclt call initshutdownscript.query" in the shell? If so nothing outputs
Kris Moore
SVP of Engineering
Administrator
Well, that explains why its not showing up in the UI then, nothing that the middleware is aware of is running... How did you add this task before? What version of FreeNAS? And can you check /etc/crontab to see if there's any hard-coded shutdown scripts in there?
Kiyoshi
I fixed my problem!! thank you for trying to help! I feel so dumb hahaha I setup my shutdown task in Cron Jobs not Init/Shutdown Scripts LOL
Kris Moore
SVP of Engineering
Administrator
Ha, well glad it was an easy fix in the end :)
