alva
- Oct 12, 2022
Hey there, I know similar questions has been asked, but for ecological and economical reasons I would like to hear your experience regarding this scenario.
My hardware is as follows:
X570 Gigabyte board
3900X AM 4 CPU
32GB DDR-Ram (no ECC but this will change)
2070 Super GPU
I am living between two countries and I sometimes need the power of my GPU for machine learning tasks as well as have to access to files from my Archive which is 4TB large + backups of my Macbook. Cloud is a good alternative but not all the time.
Sometimes means: I have to work on a project for intensive three weeks and in this time I need the GPU power as well as data. After this, the machine will run idle for 2 or 3 months. I would like to shut it down during this time.
I am aware that TrueNAS purpose is to serve files 24/7 in a local network but I don’t see the point of causing more carbon emissions than necessary.
Do you have any experience with similar use cases of utilizing your hardware and did the drives fail at one point from spinning up and down in a similar use case?
New drives also cause emissions...
From a hardware perspective I just have the experience of owning a 6 year old WD red, just to store data and it still seems fine.
Running ZFS for the Archive is to avoid bitrot - but I am not sure if this means running 24/7 is required?
I totally get the concept, but what can rot if it is not running? Scrubs and backups will be part of the process.
Thank you in advance
X570 Gigabyte board
3900X AM 4 CPU
2070 Super GPU
